gears
Old Apr 28, 2004 | 05:50 PM
squirrel masta's Avatar
From: its as intense as the time i forgot how to sit down
Default gears
what would be a good gear ratio for a turbo car,it is a six speed,and plan on making more power next year
Old Apr 28, 2004 | 05:51 PM
oh yeah its more of a driver than a racer
Old Apr 28, 2004 | 06:01 PM
PurEvl's Avatar
373 or 390 I would say
Old Apr 28, 2004 | 06:04 PM
ChevyNo1's Avatar
I'm running 3.50 . . .
Old Apr 28, 2004 | 07:02 PM
MIGHTYMOUSE's Avatar
depends completely on your goal trap speed, your tire diameter, and your max rpm (if you want to do it right)
for my 27" tires, 6500rev limit, and 150mph trap speed goal i had to go back from 3.73's to 3.42's.
look for a gear/tire calculator on the web.
Old Apr 28, 2004 | 07:45 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Stock.
Old Apr 28, 2004 | 08:20 PM
well not sure of the trap speed yet because i have not really even had it to the track ecept the one night that blew the rear,i guess the only thing would be how much better would a 3.73 be for my launch/60 ft times compared to the 3.42s
Old Apr 28, 2004 | 08:57 PM
Mike 01WS6's Avatar
3.73's will be very marginal over 3.42's in the 60'. IMHO....NOT worth it. 3.42's are stronger as well. I'd keep the stock ratio, it'd yield higher mpg, and trap speeds.
Old Apr 28, 2004 | 09:05 PM
jmeister's Avatar
i have a 2001 ws6 with 400+rwhp and i have 3.73 's with a stock rearend. would 4.10 's be better and why ?
Old Apr 28, 2004 | 09:12 PM
Packy's Avatar
I went with 3.73's, but I only upgraded because I couldn't see not getting some kind of a gear upgrade when I bought my 12 bolt. My car is more of a daily driver as well.
Old Apr 28, 2004 | 09:51 PM
qqwqeqwrqwqtq's Avatar
[QUOTE=MIGHTYMOUSE]depends completely on your goal trap speed, your tire diameter, and your max rpm (if you want to do it right)
QUOTE]
Exactly.
Old Apr 28, 2004 | 10:02 PM
jmeister's Avatar
would 4.10's make a differance in my quater mile.
Old Apr 29, 2004 | 01:14 AM
Crunch's Avatar
Go here:
http://www.1bad69.com/calc.htm
Enter in all your info under MPH calculator. That will tell you what gears to go with.
Also, remember, too much gear for an FI car is not optimal, even if you have enough RPM. Blowers/turbos like long gears. Let that boost get up in there.
Old Apr 29, 2004 | 07:04 AM
i disagree with crunch traction providing.
you always want the most gear you can sustain through the 1/4 without shifting out of 4th (stick) or third (auto)
long as it hooks you will be putting more tq to the ground
Old Apr 29, 2004 | 10:56 AM
Crunch's Avatar
true. But the reason I say that based on my experience, I won more street races with longer gears once I had the blower installed. When I was all motor, the 4.11s were great, but with the blower, you spin up the RPMs so darn quick, as soon as you step on the gas, its time to shift.
I was actually faster with longer gears. I know it sounds funny.
Old Apr 29, 2004 | 11:13 AM
Noyzee's Avatar
8 second mod
im running 3.73 right now. i havent got the chance to run yet (pissed off grunt) so im not sure, but i may need to step to a 3.50 or 342
Old Apr 29, 2004 | 12:50 PM
ok thank you guys very much it looks like im going with a 3.42
Old Apr 29, 2004 | 01:13 PM
street racing sure, different story, i gotta figure he's talking about best for 1/4.
Old May 3, 2004 | 03:01 PM
Noyzee's Avatar
8 second mod
3.42 will prob be best for you, 3.55 might be better
Old May 3, 2004 | 07:07 PM
z98's Avatar
z98
So yeah.
