76mm street Nova runs 8.39/163.75 mph!
#62
Very nice, and to think I cant get my car do do nothing close to that! Im trying to figure out how to setup the spark table. Do large cams need a lot of timing before boost?
#64
Damn, that thing is badass. I know what I'll be doing to my Nova once I'm done playing around with the nitrous sbc in it now..... What fuel injection system are you using? That's a pretty small cam in there, would it pick up any if you went to a larger custom grind?
#70
Thanks. It has a full exh to rear axle. 4" pipe with magnaflow muffler.
Shift is at 6600 rpm. I still have a stock case glide with stock plannets. Saving up for a stronger trans. Prob wont see a trans brake launch from this car unless it is in competition, or $ on the line.
#74
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
