STS kit vs Custom Rear Mount?
My question is, would it be cheaper and better to buy a used sts kit or to buy used parts (turbo, wg, fmic,...) and have a shop custom build the plumbing?
I'm not looking for anything crazy, just a 450-500rwh weekend warrior. For those of you who have a sts kit or custom rear mount, would it be possible to do an entire build with tune for around $2000-2500?
Car is a bolt on A4. I was originally thinking of going the HCI route but have been toying with the idea of a turbo for a while.
Thanks in advance!
I did a complete (and still perfecting) a complete custom rear mount turbo and im still at about $5000+ although this is with EVERYTHING, its still no where the low cost you're mentioning. You "might" be able to if you find someone trying to get rid of a sts basic kit and arnt looking to get back their money.
If your not in a hurry, if you can get the pipe work, get that, and then upgrade all the sts supplied hard parts like the turbo, oil pump, intercooler
its a trial and error experience unless you have dont this before. Testing is the fun part and learning what works and what doesnt has its reqards personally if you go the fabricated route.
Take the extra money and buy a quick spool valve (or second wastegate), with a twinscroll turbo like Zombie and go get a dyno-tune. Spend less and go just as fast with no lag as a front mount. I got full boost in first gear under 3000 rpms on a little six banger.
whaat you need to remember whats really gonna cost you regards of route is tuning. Expect at least $600 unless you got aa hook up. I paid $200 for hp tuner credits alone, and then $600 for custom SD 2 bar MAP tune and then had to pay another $200 for a separate tuing session that didnt even get to finish due to boost leaks.
The least amount of "joints" in the intake and exhaust stream, the less amount of potential boost leaks. im having an issue with my ypipe since i cant get a welder to properly weld the tops of where the exhaust sits to seal up the exhaust leaks and is causing my own issues. i started my setup wrong with long tube heads ( a rear mount nono) and 3" OR ypipe. im in the process of looking for a 2.5" ypipe to gain some heat and pressure and under car clearance. i actually managed to get all the pipe save for one in the back, out from under the car
which is now making my ypip the lowest part of the car that is still scrapping on some road iregularitys. youll have to look into my thread to find that one out
By the way, are you going to use the "Anti Lag" like I mentioned. I don't have hardly any lag with the twinscroll and second WG.
Just my experience, if you are going to have any fun with the car at all I would save up for a tranny as well.
. It is night and day difference from what you experience now. I see that you hae the On3 turbo in your build. I went to Ebay and purchased a GodSpeed T4 turbo with a .86AR twinscroll housing. Funny thing is the same CHRA on my Masterpower .70AR twinscroll fit the Ebay. They really are clones ! Now you might be able to get a housing on the cheapside on Ebay that will fit that turbo. I would look for a .96AR twinscroll (because it wil be essentially halved to .48) to give that down low punch and excellent top end.
http://en.wikipedia.org/wiki/J-B_Weld
"The product J-B WELD is a two-part epoxy adhesive (or filler) that can withstand high-temperature environments. J-B WELD can be used to bond surfaces made from metal, porcelain, wood, ceramic, or glass,[3] plus marble, PVC, ABS, concrete, fiberglass, wood, fabric, or paper.[4] Avoid using alcohol to clean surfaces.[5] J-B WELD is water-proof, petroleum/chemical-resistant (when hardened), acid-resistant, plus resists shock, vibration, and extreme temperature fluctuations.[4] J-B WELD can withstand a constant temperature of 500 °F (260 °C), and the maximum temperature threshold is approximately 600 °F (316 °C) for 10 minutes."
Joshua, i've been following your build from the start, i have long tubes and 3in exhaust on my car now. i picked up some stock 2001+ ls1 exhaust manifolds and i bought the down pipes, y pipe, and intermediate pipe from walker (aka dynomax), my down pipes do not have cats like the ones in the picuture, but they have all the flanges, o2 bungs, and clamps (im going to have mine welded), ill have to measure mine if your interested i think they are 2 3/4, as you can see the intermediate pipe is "wrinkle" bent, its not as good as mandrel but better then exhaust shop "crush" bend. i have not found any other affordable options
summit has the info here
http://www.summitracing.com/parts/wlk-88028
http://www.summitracing.com/parts/wlk-55282
