Who makes the best flowing heads for 4.030 bore and a THICK deck......for my 390ci...
Old 08-12-2013, 10:49 PM
LS6427's Avatar
Originally Posted by Detoxx03
The LSA's are a nice budget option but I'd opt for the Mast heads.
I know the MAST stuff is good....but I want to only spend the money I need to spend to reach my goal. No need to just completely throw money away.
If PRC 247's will make 1,100+ RWHP or another cheaper thick deck head.....I'll get those.
Old 08-12-2013, 10:59 PM
LS6427's Avatar
How about these Mast heads.....will they make 1,100+ RWHP
Cathedral Port 215cc Small Bore LS1 / LS6 CNC Assembled (3.9000"-4.070" Bore)
$2,400 for the pair, assembled.
Old 08-14-2013, 10:38 PM
DEFYANT's Avatar
Any head can make those numbers, it will just take more boost.
Old 08-14-2013, 11:17 PM
LS6427's Avatar
I want a head that will make the most power with the least boost.......
Maybe the question is......if I can find a head that flows 380-390cfm @ .600, I should use it....right....?
Old 08-15-2013, 06:17 AM
SMOKNSS's Avatar
I'm using LSA heads. They have already been over the 1000rwhp mark in stock form. AI and TEA will even port them for under $700.
Old 08-15-2013, 10:41 AM
bad6as's Avatar
Trick flow cnc 225s on mine
Old 08-15-2013, 11:25 AM
Sales@Tick's Avatar
Trick Flow 235's.
Andreas went 6.70's with those heads. Mike Brown went 7.30's with a hydraulic cam and TFS 235's.
Proven power.
Old 08-15-2013, 03:37 PM
Detoxx03's Avatar
Looks like people are liking and having good results with the PRC 260's. They are on my radar as long as they keep performing well. Being priced well helps a lot too.
Old 08-15-2013, 07:11 PM
LS6427's Avatar
You mean PRC 265's......?
I know we don't need the best flowing heads to make big power with BOOSTED set ups.
But should I get the best flowing heads possible for the money I have to spend.......? What will this do for my TT set up......allow more power with less boost...?
That's a big plus since I have 4 bolts per cylinder only......right...?
Also, I see there price is $2,399 for the PRC 265 heads.....IS THAT FOR BOTH HEADS....?
Well these heads work on my 390ci iron engine with flat top pistons?
Old 08-15-2013, 07:48 PM
DEFYANT's Avatar
If you want a head that flows 380-390 @ .600" Lift you would need some worked AllPro or similar style head (I would do LS3 Style) If you want a good budget head that flows great the PRC 260 is what you need.
Old 08-15-2013, 08:13 PM
Detoxx03's Avatar
No I meant 260cc
http://www.texas-speed.com/p-4010-pr...der-heads.aspx
Old 08-16-2013, 09:14 AM
  #32
Sales@Tick's Avatar
Honestly for a motor with an OEM style intake, the larger CSA of the larger port volumes isn't necessary.
I would go with the 250's on anything with a OEM style(a la Fast, LS6, LS7, LS3 etc.).
Old 08-16-2013, 08:05 PM
  #33
LS6427's Avatar
I don't see that they have a thicker deck.....I definitely need a thicker deck head......
And is that price of $2,300 for BOTH heads......?
Old 08-16-2013, 08:06 PM
  #34
LS6427's Avatar
250's.....?
Old 08-17-2013, 01:43 AM
  #35
Detoxx03's Avatar
It doesn't say it but they do and yes that's for both heads.
Old 08-17-2013, 08:12 AM
  #36
LS6427's Avatar
Cool, thanks.
Wow......seems like a great price for assembled heads.
Old 08-17-2013, 10:54 PM
  #37
Sales@Tick's Avatar
250's.....?
250cc intake port.
Old 08-18-2013, 04:12 PM
  #38
chrs1313's Avatar
Trick Flow 235's.
Proven power.
Pretty sure he has mast heads now for the 6.70 pass...still badass example, iirc it did like 1680hp flywheel with lsx and 235 TFS
Also another great car is turbo Tim's pinto 7.7s at 177mph with out of the box 225 TFS 4 bolt heads and iron stock block 6.0 408
Old 08-18-2013, 06:25 PM
  #39
Sales@Tick's Avatar
No. He went 6.70's with TFS 235's. He has never run Mast heads. He has Warhawk heads now and a Warhawk block.
He has been 6.20's with the Warhawk block and heads.
Old 08-19-2013, 09:16 AM
  #40
chrs1313's Avatar
I stand corrected, TFS always seem to get it done....
Do you have a link to any of those passes or a thread, it has been awhile since I read up on his car
Thanks
Chris
Quick Reply: Who makes the best flowing heads for 4.030 bore and a THICK deck......for my 390ci...
