Datsun 280z Turbo Build - 5.3 / T7875 / Magnum T56 - Video on page 12!
#101
Well in rust's true form, the more you look - the more you find.
Went down the rabbit hole and cut out all the bad spots on the passenger's side.
![](http://i592.photobucket.com/albums/tt4/steepss/SidwayZ/IMG_20140227_203352_302_zpstvipggy8.jpg)
Also got the passenger's side rail all welded in, save the floor pans.
![](http://i592.photobucket.com/albums/tt4/steepss/SidwayZ/IMG_20140227_215253_871_zpsroamlkli.jpg)
Thats all for now. Hope to have the floor pan in and the driver's side rail completed by the weekend.
#103
Didn't quite get everything done I'd hoped. Life gets in the way, ya know?
Here's the driver's side frame rail before I removed it. Not nearly as bad as the other one, but still needs upgraded
![](http://i592.photobucket.com/albums/tt4/steepss/SidwayZ/IMG_20140301_141703_525_zpsyaqpyk6t.jpg)
Shot of the driver's rail removed, looking to the passenger's side
![](http://i592.photobucket.com/albums/tt4/steepss/SidwayZ/IMG_20140301_180630_136_zpsszb9jyhx.jpg)
Here is how I drew the cut line....
![](http://i592.photobucket.com/albums/tt4/steepss/SidwayZ/IMG_20140302_180511_541_zpsce57wbzr.jpg)
First cut:
![](http://i592.photobucket.com/albums/tt4/steepss/SidwayZ/IMG_20140302_181512_021_zpsizslltnp.jpg)
Made a second cut 1/2" inboard to give me an edge to weld. Used a hammer and dolly to flatten out the trans tunnel side and made a few relief cuts. You can see where I peeled back the floor at the tie-in point. Hope to bend that back down and close the floor when done.
![](http://i592.photobucket.com/albums/tt4/steepss/SidwayZ/IMG_20140302_192708_563_zps63ymab4l.jpg)
Test fit
![](http://i592.photobucket.com/albums/tt4/steepss/SidwayZ/IMG_20140302_184251_607_zpsaxmaajvf.jpg)
RUST cut out.....
![](http://i592.photobucket.com/albums/tt4/steepss/SidwayZ/IMG_20140301_200919_768_zps9elkawva.jpg)
Battery tray and other rust removed.
![](http://i592.photobucket.com/albums/tt4/steepss/SidwayZ/IMG_20140301_200935_411_zps65ldxqbo.jpg)
Looking a little bare
First cut:
Test fit
RUST cut out.....
![](http://i592.photobucket.com/albums/tt4/steepss/SidwayZ/IMG_20140301_202851_302_zpshyz2m6ep.jpg)
#106
Driver's side complete
![](http://i592.photobucket.com/albums/tt4/steepss/SidwayZ/IMG_20140307_214722_112_zpsikqq5hpn.jpg)
Again
![](http://i592.photobucket.com/albums/tt4/steepss/SidwayZ/IMG_20140307_214821_167_zps8hlyuthc.jpg)
Another shot from the driver's side:
![](http://i592.photobucket.com/albums/tt4/steepss/SidwayZ/IMG_20140304_221224_399_zpstv0oyttl.jpg)
Just a couple spots to fill!
![](http://i592.photobucket.com/albums/tt4/steepss/SidwayZ/IMG_20140308_161800_400_zpsnrntfh21.jpg)
Here's one showing the flange for the inner fender removed.
![](http://i592.photobucket.com/albums/tt4/steepss/SidwayZ/IMG_20140308_180624_564_zpsypu8care.jpg)
Floor pan in, starting on firewall.
![](http://i592.photobucket.com/albums/tt4/steepss/SidwayZ/IMG_20140308_182556_590_zpsyrgnyela.jpg)
From the inner fender
![](http://i592.photobucket.com/albums/tt4/steepss/SidwayZ/IMG_20140308_185412_248_zpsup4ymto5.jpg)
Floor pan and upper section in:
![](http://i592.photobucket.com/albums/tt4/steepss/SidwayZ/IMG_20140308_190045_696_zpszxlgvgzs.jpg)
Using my sheet metal "brake" aka a line and a hammer! lol
![](http://i592.photobucket.com/albums/tt4/steepss/SidwayZ/IMG_20140309_191358_547_zps9tfiji0b.jpg)
Bottom section in:
![](http://i592.photobucket.com/albums/tt4/steepss/SidwayZ/IMG_20140309_193803_610_zpskk06ayil.jpg)
From the bottom before welding
![](http://i592.photobucket.com/albums/tt4/steepss/SidwayZ/IMG_20140309_204941_951_zpsgoqvitjz.jpg)
Burned in
![](http://i592.photobucket.com/albums/tt4/steepss/SidwayZ/IMG_20140309_211826_054_zpsbni7npte.jpg)
Pass. rail
![](http://i592.photobucket.com/albums/tt4/steepss/SidwayZ/IMG_20140309_211836_511_zps0wunzaos.jpg)
Driver. Small amount of work to do on the floor pan where someone "clearanced" it.... Grrr
![](http://i592.photobucket.com/albums/tt4/steepss/SidwayZ/IMG_20140309_205016_250_zpssngqfxqy.jpg)
New Inner fender support / firewall tie- in
![](http://i592.photobucket.com/albums/tt4/steepss/SidwayZ/IMG_20140308_185428_351_zpsgj9yxmxs.jpg)
![](http://i592.photobucket.com/albums/tt4/steepss/SidwayZ/IMG_20140308_185454_167_zps6tkvimbd.jpg)
From the top!
![](http://i592.photobucket.com/albums/tt4/steepss/SidwayZ/IMG_20140309_224503_452_zpsniyy9b8r.jpg)
Battery tray out and new metal in. Not sure if i'm going to put the battery back in there or relocate it.
![](http://i592.photobucket.com/albums/tt4/steepss/SidwayZ/IMG_20140309_224702_843_zpslaa6bpyj.jpg)
Inner fender finished
![](http://i592.photobucket.com/albums/tt4/steepss/SidwayZ/IMG_20140309_224536_939_zpsrkcalwak.jpg)
And look what showed up.![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Again
Bottom section in:
Burned in
Pass. rail
From the top!
![](http://i592.photobucket.com/albums/tt4/steepss/SidwayZ/IMG_20140309_225321_916_zpssqu715nw.jpg)
#107
Mikey303LSZ, on 11 Mar 2014 - 10:33 PM, said:
Welds look nice. Lots of work. You work fast...
Thanks... Never fast enough though it seems.
Knocked the undercoating off the drivers side inner fender, and started to replace some sheet metal that I'd neglected in the past.
![](http://i592.photobucket.com/albums/tt4/steepss/SidwayZ/IMG_20140311_220736_556_zps08wqycy1.jpg)
Eek.
Eek.
![](http://i592.photobucket.com/albums/tt4/steepss/SidwayZ/IMG_20140311_220435_028_zpsy0hlrkt2.jpg)
#109
Small update:
I cut my x pipe in half, and made a transition to a 3.5" pipe with Vband connection.
![](http://i592.photobucket.com/albums/tt4/steepss/SidwayZ/IMG_20140316_171943_651_zpso9eazkpc.jpg)
Started removing someone's poor patch job, to find... more rust.
![](http://i592.photobucket.com/albums/tt4/steepss/SidwayZ/IMG_20140316_195208_715_zpsfbyygvkm.jpg)
![](http://i592.photobucket.com/albums/tt4/steepss/SidwayZ/IMG_20140316_195734_478_zpsyusx6pud.jpg)
![](http://i592.photobucket.com/albums/tt4/steepss/SidwayZ/IMG_20140316_195749_468_zpsxjif037k.jpg)
Marked
![](http://i592.photobucket.com/albums/tt4/steepss/SidwayZ/IMG_20140316_204649_962_zpsmovdqrcj.jpg)
Cut out, and new piece in
![](http://i592.photobucket.com/albums/tt4/steepss/SidwayZ/IMG_20140316_213532_578_zpsh7qauqw2.jpg)
![](http://i592.photobucket.com/albums/tt4/steepss/SidwayZ/IMG_20140316_213558_319_zpsaanyxnvj.jpg)
Thats all for now. Hope to finish this out in the next couple days.
Marked
#110
Lots of time in this revision, but it will be sweet when done. Did you sell off the old 5.7/AFR head deal? The iron block and turbo setup will add a decent amount of weight to the front end, did you think about an aluminum 5.3? Any work to the heads(which casting are they anyway)?
#111
The 05 iron block was given to me, and needs rings and a cam - which I intend to do.
I'm not terribly concerned with the weight, though I'd like it to be lighter. I'll keep my eye out for an AL 5.3, but last I saw they were bringing pretty good money.
Heads will be stock 706's (non-castech). BTR springs / Ti retainers, with new seals.
#112
Steepss, the build is looking good, going to be a sweet ride.
What intercooler are you running, if you have a website and or dimension
of the cooler it would really help. is it 3" inlets and outlets? whats the power rating ?
#117
Impressive. I didn't see this one coming. So now with the new trans and clutch, ford rear, DSS axles, etc. What would you say the weak point is? I am curious what spare parts you will be bringing to the track this year. I know last year you had a couple axles in tow.
#119
Got some mud laid down on the "roll pan".
Still need to give it a final prep, and then some paint, but it looks much better than before.
![](http://i592.photobucket.com/albums/tt4/steepss/SidwayZ/IMG_20140322_112705_693_zpsufbvi3f7.jpg)
Started test fitting the Magnum T56
![](http://i592.photobucket.com/albums/tt4/steepss/SidwayZ/IMG_20140323_221502_051_zpsy77sivji.jpg)
![](http://i592.photobucket.com/albums/tt4/steepss/SidwayZ/IMG_20140323_221510_990_zpsjlphvm7x.jpg)
Handy silicone coupler for a template
![](http://i592.photobucket.com/albums/tt4/steepss/SidwayZ/IMG_20140324_171039_790_zpsbukxokq1.jpg)
![](http://i592.photobucket.com/albums/tt4/steepss/SidwayZ/IMG_20140324_171057_600_zpsbpil4k8l.jpg)
Done
![](http://i592.photobucket.com/albums/tt4/steepss/SidwayZ/IMG_20140324_172358_563_zpsjqc8nzy4.jpg)
Also started piecing together my fuel system. Ugh. I have a lot of fittings and line to buy. This will all be on the bottom of the tank... for clarification.
Done
![](http://i592.photobucket.com/albums/tt4/steepss/SidwayZ/IMG_20140324_194527_343_zpspwfhck4h.jpg)
#120
Worked on the heater hose plumbing last night.
Here are the bulkheads I made. -10 Steel bung welded to a 3/8" npt bung. Inside the firewall will be a 90* elbow to a standard heater hose connection.
![](http://i592.photobucket.com/albums/tt4/steepss/SidwayZ/IMG_20140325_214836_672_zpsa09nfysh.jpg)
Lots of work, but it'll be worth it in the finished product, and ease of access to heater hoses, as they were behind the pass. head before, and a real PITA to get to.
