s366 4.8 Camaro 6speed, Steven Sigmon
Old 02-04-2014, 10:23 AM
  #121
mrstepheneades's Avatar
Originally Posted by Siggy25
Attachment 436895
Had a fuel pressure problem, blew a hole in the fuel pump hose
Told you when you text me it was fuel related. We had a Camaro once at work that would crank and run but not rev more than 1300rpm. Could baby it around the parking lot but any gas much and it would die. It was running on less than 10psi of pressure. Learning experience for me because im use to things needing a certain amount of pressure to even run. Nothing that low.
Old 02-04-2014, 01:47 PM
  #122
Siggy25's Avatar
It's fixed now, was gonna put that ls6 cam in today but decided that I didn't feel like messing with my car anymore. Maybe next month
Old 02-04-2014, 07:42 PM
  #123
I got another spring here waiting lol
Old 02-05-2014, 08:31 PM
  #124
Siggy25's Avatar
What pound spring do you have. Changing cam next Saturday. And this is a question for everyone, if I put a ball valve inline of the wastegate boost line and closed it some would it allow more boost to be made or be the same.
Old 02-05-2014, 08:55 PM
  #125
I have the lightest springs in the box. I'll give you whichever one you want or else you can do the ball valve thing. The more air/boost you allow to the top port on the waste gate the more boost turbo will yield. If your gonna do ball valve just leave the spring alone. Just crack the valve a little and watch boost and inch it up as you want. I always test mine at highway speed on 4th. That's your most load and shouldn't have to get more than 4000 to see whatever the max its gonna max. If not enough crack valve open a little more.
Old 02-05-2014, 09:10 PM
  #126
Siggy25's Avatar
Yeah I will just use the ball valve, probably have Jonathan take it down the road first to tune the cam in and have the ball valve closed a little and see what it hits on the street. Looking to hit 13 to 14 bc I know it won't get but 11 or 12 on the dyno if I can get 14psi on the street. But I would just like to see the diff between the new cam at 8 psi. And I will mark the ball valve at the desired psi.
Old 02-05-2014, 09:11 PM
  #127
Siggy25's Avatar
Don't want to get any higher than 14psi with out meth
  #128
Forcefed86's Avatar
I wouldn't use a ball valve. Use a mini pneumatic regulator. Much more adjustability and it locks. Harbor freight has them dirt cheap. or Ebay sears etc...
like this...
http://www.harborfreight.com/14-mini...uge-68226.html
pop the gauge off and plug it, mount **** close to driver and you can adjust boost on the fly. Plumb it like so. Happy face sticker on the **** is an optional upgrade...
Old 02-05-2014, 09:14 PM
  #129
Siggy25's Avatar
I didn't even think about using a regulator. I will just have to pick me one up from lowes or find me one at work. Thanks for that idea
Old 02-06-2014, 09:20 AM
  #130
got-a-ls1's Avatar
the ball valves block the reference line of boost signal until the desired boost level is reach. helps spool
Old 02-06-2014, 09:42 AM
  #131
Forcefed86's Avatar
This is a ball valve…
Your thinking of an adjustable spring loaded check valve. (sometimes called a grainger valve) Adding one of these inline can help with spool assuming the spring in your gate is well below your desired boost level. Putting one by itself inline would cause boost to pulse. You would need a bleed of some sort in addition. You could use one with the pneumatic regulator.
Old 02-06-2014, 09:57 AM
  #132
got-a-ls1's Avatar
well i was using his terminology lol yes i meant a ball and spring or grainger valve. i didnt realize he meant an actual ball valve haha. i use a hallman and have made a home made one as well
Old 02-06-2014, 03:13 PM
  #133
Hallman here too.
Old 02-06-2014, 03:53 PM
  #134
Camaro9969's Avatar
If you want a hallman I have two pros that im selling pm me if your interested.
Old 02-19-2014, 08:11 AM
  #135
lq4powereds13's Avatar
Any updates after installing the ls6 cam? Doing a similiar setup soon except it will be going on a 5.3l with ls6 cam.
Old 02-19-2014, 09:04 AM
  #136
Siggy25's Avatar
Was gonna put ls6 cam in this past sat but with this snow storm we had Thursday delayed that. Hopefully will changes cam this sat. Then the following sat I will have results.
Old 02-19-2014, 09:14 AM
  #137
So your going back to tune some more?
Old 02-19-2014, 03:17 PM
  #138
Siggy25's Avatar
Yes, want to see power difference and also see how my free boost controller will work lol
Old 02-19-2014, 04:25 PM
  #139
Sounds good. Looking forward to seeing some mid 500s at least. Don't be weak lol. Jk.
Old 02-21-2014, 06:29 PM
  #140
Siggy25's Avatar
I'm weak bc I'm broke lol
Quick Reply: s366 4.8 Camaro 6speed, Steven Sigmon
