s366 4.8 Camaro 6speed, Steven Sigmon
Old 03-21-2014, 12:32 PM
  #161
Sales@Tick's Avatar
It still needs a different cam IMO.
A 215/215 113lsa cam would rip in this set-up.
Old 03-21-2014, 02:19 PM
  #162
got-a-ls1's Avatar
2 1/2 inch downpipe must be effecting spool cause even my pt7675 was full boost by 3-3500rpm depending on where i floored it, ls6 cam as well 3 inch downpipe. i will have my s366 setup together here shortly. trying a stock 98 cam if that doesnt work well ill throw in my tu1
Old 03-21-2014, 02:21 PM
  #163
got-a-ls1's Avatar
how much boost was that on anyways?
Old 03-21-2014, 02:30 PM
  #164
lq4powereds13's Avatar
What size piping on the hotside/merge did you use? Didn't see it mentioned in the thread.
Old 03-21-2014, 04:05 PM
  #165
mrstepheneades's Avatar
We used 2.25 on it.
Old 03-21-2014, 07:50 PM
  #166
got-a-ls1's Avatar
Originally Posted by Sarg
I Am sure the downpipe will help some. Still seems likeit would have mad low end torque though, lol.
i bet 4.10 gears coupled with being a dynojet could attribute to that as well (unless this one is a loaded dynojet)
Old 03-22-2014, 08:00 AM
  #167
Siggy25's Avatar
8.5psi
Old 03-22-2014, 08:12 AM
  #168
Originally Posted by Siggy25
8.5psi
We get you to at least 12psi next weekend. That should yield another 50 couple rwhp id think on the low end.
Old 03-31-2014, 07:38 AM
  #169
Well I got the downpipe done on Stevens car this weekend. Here are some pics of his old one. Lol sorry Steven I had to post them. I know you were working with what you had.
The Old One. 3.5" down to 3" down to 2.5"
Old 03-31-2014, 07:46 AM
  #170
And for the New downpipe. 3.5" all the way out and new flange from Race Parts Solutions. Picked up 3-4 psi just from this new downpipe changing nothing else.
Some of the stainless bends are defects from KOOKS that why this one has a slight roll in it. Helping him keep cost down.
Old 03-31-2014, 07:49 AM
  #171
One more thing. Don't use a cheap clamp on your cold pipes. After the new downpipe we when for a ride. Now the car makes 13psi and it blew the pipe off lol. Messed radiator up and ripped wires out of iat sensor. Radiator still holds fluid but just looks messed up. I gave him a nice tbolt clamp to put back on so this wont happen again.
Old 03-31-2014, 05:53 PM
  #172
Sales@Tick's Avatar
Nice! Everything but the radiator carnage that is...lol.
Old 03-31-2014, 05:56 PM
  #173
stevieturbo's Avatar
Whilst it's always wise to use quality clamps.
The problem there is mostly due to a non existent bead/lip on that TB.
Tightening the crap out of it with strong clamps is one solution, but not always the best.
Old 03-31-2014, 09:21 PM
  #174
Real men have to vband the throttle bodies lol.........
Old 03-31-2014, 09:43 PM
  #175
He will be at the track with us if his schedule allows. He will be on 16" salad shooters and slicks.
Old 04-01-2014, 12:32 AM
  #176
got-a-ls1's Avatar
nice. seems to be a big improvement. curious if spool response was better
Old 04-01-2014, 08:18 AM
  #177
To tell you the truth I really didn't pay attention. If he gets back to the dyno Jonathan can overlay the graph and see the difference.
Old 04-01-2014, 05:30 PM
  #178
Siggy25's Avatar
I haven't driven it enough to see if it spools sooner.
Old 09-26-2014, 10:25 AM
  #179
Got Steven's car back in the shop to do address a few issues. For one a major boost leak thru the iat sensor causing max boost to be 10psi regardless. Going to install an exhaust trim ring also and put a lt1 cover on the top of the radiator. He still needs a turbo blanket and a few things but its getting there. Hopefully today I will see 15psi or so when I take it out for a test after fixing leak and adding another spring in the gate.
Old 09-27-2014, 06:07 AM
  #180
A long evening with this car trying to figure out why it will not make more boost. I checked intake, lines behind intake, all vacuum lines in general going to the wastegate and bov, all couplings and clamps and cold piping, took intercooler off and pressure tested with air, fixed iat sensor where no air will pass through it, checked tb gasket, added another spring in the wastegate and still not but 10psi at peak. Made a super thick aluminum cap off plate for the vband wastegate port and capped it of to see if there was a problem with the wastegate. Its a JGS 50mm and ive never heard of them having problems. Took the car out and it hit 12psi and felt like it picked up 100rwhp across the rpm band. Rolls third off as soon as boost comes in and tires are spinning a little in fourth as well. Also the response is half the time it was. It probably will not stay capped off for long before the gate goes back on but it is puzzling why it will not produce more boost pressure. Also took EGR Block off plate off and checked oring and looked into intake to make sure the intake valley plate was intact.
Specs again are:
4.8
243's
LS6 Cam/with springs/pushrods, all the normal cam stuff.
BBK Aluminum Intake
S366 with 1.00ar/73mm turbine
3" CX Racing Intercooler
JGS 50mm Wastegate
HKS BOV
Its on straight 93 pump gas and 16 degrees of timing according to the tuner (Jonathan@Tick)
Maybe it could be something with the valvetrain bleeding boost off? Maybe a restriction from the intercooler? Got me scratching my head!!!
I did put a lt1 cover over the radiator which he provided and also an exhaust trim ring on. Car looks a lot cleaner.
Quick Reply: s366 4.8 Camaro 6speed, Steven Sigmon
