LQ4 370 Kytp build
Old Dec 30, 2013 | 09:27 AM
  #41
allout06's Avatar
Good looking build. i do have 2 suggestions..
1. Dont cross over your fuel line in the front. For a FI setup, the best way to run your fuel system is to feed the back or the front of each rail individually via a Y. then come off the front/back (opposite end of where you fed them) and go to your FPR. itll give the injectors on both bank even pressure/flow.
2. those harlan sharp rockers are going to break. the stock rockers with the trunion upgrade are your best bet. I was going to run them and AES told me to save my money along with me seeing a lot of them break.
just my .02
Old Dec 30, 2013 | 11:28 PM
  #42
wes96z's Avatar
Thanks for the advice I'll look into the fuel system suggestion as far as rockers they are the stock ones rebuilt upgraded with c clip by Harland sharp do you think I'll have a problem with them?
Old Dec 31, 2013 | 12:32 PM
  #43
supersick99z's Avatar
how are you running your drain and feed? and what sizes?
Old Dec 31, 2013 | 12:50 PM
  #44
allout06's Avatar
o, if they are a stock rocker with a bearing upgrade, youll be fine. i thought you bought actual harland sharp rockers.
Old Jan 1, 2014 | 10:49 AM
  #45
wes96z's Avatar
Drain is ran into the top driver side of the pan and feed is coming from the clean side of where the oil filter goes.
Old Jan 1, 2014 | 10:52 AM
  #46
wes96z's Avatar
Well I got the base tune in the car yesterday, it idles a lot better now I still hve not gotten to take it out since my allignment is way off from the turbo k member install so hopefully tomorrow I will be able to get that taken care of and will try to get some video.
Old Jan 1, 2014 | 02:38 PM
  #47
wes96z's Avatar
Originally Posted by wes96z
Cold side going together, the radiator and fans worked out great hard to tell by the pic but there's actually quite a bit of distance from the turbo to the fans
I'm a little worried the blow off valve may be sitting a little high not sure the hood will clear it
Well I guess my hood issue was not an issue
Old Jan 3, 2014 | 09:38 AM
  #48
wes96z's Avatar
Got the alignment done yesterday and took the car out for the first time i put about 25 miles on it when I came back to the house to check everthing out i noticed some oil dripping under the car i popped the hood and noticed it looked as if though a mist of oil was spraying my intake and the back of the fire wall it mostly looked wet on the driver side. My guess is my valve cover seal is bad but im not 100% on this, ill do some more investigating has anybody else had this happen know of a possible cause???
Old Jan 3, 2014 | 03:14 PM
  #49
wes96z's Avatar
TTT any insight or possibilities on the above post would be appreciated
Old Jan 3, 2014 | 03:19 PM
  #50
geoff17's Avatar
Oil pressure sending unit is behind the intake on the drivers side, maybe check there?
Old Jan 5, 2014 | 09:47 AM
  #51
wes96z's Avatar
got the oil spray issue fixed, I replaced my valve cover gaskets and also my driver side valve cover had no pcv valve on it, it was capped off so I got a valve placed it in there and ran a hose to a T valve and connected it to the passenger side pcv port on the back i capped the front one and ran the other side of the T to my catch can. So far it seems to have taken care of that issue.
Old Jan 5, 2014 | 09:50 AM
  #52
wes96z's Avatar
Got some shake down vid
cutout open
cutout closed
Old Jan 5, 2014 | 10:08 AM
  #53
Heavy H.P.'s Avatar
Are you able to really open her up yet?
Curious to see how she runs WOT.
Old Jan 5, 2014 | 10:13 AM
  #54
wes96z's Avatar
Ive only put about 85 miles on it so far so im hoping to get about 500 before it goes to get the full dyno tune then ill update this thread with results and more video. Its hard to keep my foot out of it until then though
Old Jan 5, 2014 | 10:19 AM
  #55
Heavy H.P.'s Avatar
Oh I don't blame you. Not looking forward to it on mines also. Looking at your video I kept looking at the EBoost2, instead of seeing numbers I kept seeing WOT WOT WOT
Old Jan 5, 2014 | 06:46 PM
  #56
rorric's Avatar
Awesome build man hope to do it to mine soon... After seeing your area in the video sun shinning makes me want to move .. lol Here in Michigan we just got a foot of snow.. lol
Old Jan 6, 2014 | 09:05 PM
  #57
bmr408's Avatar
kick a$$ man nice build
Old Jan 9, 2014 | 02:18 AM
  #58
EvilArc's Avatar
Glad to see that car back on the road after all the time it spent as a paper weight in your garage! When you get it broke in and a good tune in there let me know... I'll race you from 31st to 29th Ave! Hahaha
Old Jan 19, 2014 | 12:42 AM
  #59
wes96z's Avatar
Old Jan 19, 2014 | 01:09 AM
  #60
89jyturbo's Avatar
Numbers? Sounds real mean.
Cam specs?
