LQ4 370 Kytp build
Old Jul 10, 2014 | 02:47 AM
  #81
wes96z's Avatar
Well during the install of my rear end I discovered my indestructible 10 bolt is still intact and I had infact broke the output shaft on my T 56 so more down time for the car while I wait for a new transmission I went with the level 7 RPM Magnum TR6060 I should hopefully have it in the next couple of weeks and get this thing back on the road. I also am upgrading my injectors so I can run E85, ill post new numbers with the bigger turbo on E85 set up.
Old Jul 29, 2014 | 04:19 PM
  #82
wes96z's Avatar
Got some progress done, rear end is installed transmission is in, I still have the turbo clearance issues but I am having to redo my exhaust to clear the new rear so I'll address the hot side at the same time. Here's some pics sure is pretty.
Old Jul 29, 2014 | 04:28 PM
  #83
SM105K's Avatar
That thing is clean. Do you ever take it to any meets?
Old Jul 29, 2014 | 04:38 PM
  #84
wes96z's Avatar
I haven't in a long time I'm not really sure of any active boards in phoenix it seems azfba doesn't work anymore but once I get this thing back on the road and kinks worked out I'm sure I will
Old Jul 29, 2014 | 04:41 PM
  #85
SM105K's Avatar
Azfullthrottle.com is the best AZ board. It is basically a mini yellow bullet. There are quite a few turbo f-bodies roaming around the valley. I know of 5 more including myself.
Old Jul 29, 2014 | 05:08 PM
  #86
wes96z's Avatar
Cool I'll make an account over there and check it out I was curious if there were other turbo guys in the valley besides nic d
Old Jul 30, 2014 | 08:56 AM
  #87
SM105K's Avatar
It is a pretty tough crowd as you saw over there. There are alot of fast turbo cars in the valley now.
Old Jul 30, 2014 | 06:30 PM
  #88
wes96z's Avatar
Yeah I noticed that does everybody get together from time to time Id like to check out some of these fast cars
Old Jul 31, 2014 | 08:30 AM
  #89
Ryans99ls1's Avatar
Whats your driveshaft length and what are you using to get your speedo right?
Just put a 6060 in my car and the speedo is way off
Old Jul 31, 2014 | 10:51 AM
  #90
SM105K's Avatar
51st and Bell on Saturday nights after the Pavs. About 10pm.
Old Jul 31, 2014 | 03:46 PM
  #91
wes96z's Avatar
Not sure on the driveshaft I ordered it from Midwest Chassis with my rearend told them what transmission I was running and they specd it out for me, as far as speedo I have not driven the car yet still tying up a few loose ends so im not sure maybe call whoever you got your trans from. Im curious to see if my speedo will be off as well?
Old Jul 31, 2014 | 03:47 PM
  #92
wes96z's Avatar
Southeast corner in the Harbor Freight parking lot?
Old Aug 1, 2014 | 04:53 PM
  #93
SM105K's Avatar
Yes sir. I will be there, not in my car however. Look for the big a Maroon Dodge Diesel.
Old Dec 20, 2014 | 04:22 PM
  #94
wes96z's Avatar
Took me a while to get the bugs worked out but just got back from the dyno with the new turbo, put down 763hp 788tq at 14lbs
Here is the graph 1st run was on 7lbs second run 10lbs and we stopped at 14lbs
