Twin Turbo LSX Datsun 280Z
Old 05-12-2015, 09:37 AM
  #881
ablakez28's Avatar
I run NPT(1/8" IIRC) to -6 AN for my glides to the cooler typically. I have come across more than one cracked housing from over tightening.
I look forward to seeing the results from the steep gear and using OD gears.
Old 05-12-2015, 09:40 AM
  #882
oscs's Avatar
Thanks,
I opted for an aftermarket case so hopefully i don't run into that problem.
Old 05-12-2015, 12:52 PM
  #883
Forcefed86's Avatar
So whats the ruff total damage shipped to your door on the GV unit and glide combo together? Was the install procedure pretty straight forward? Just bolted on?
Need to know a nice round figure so I know which organ I have to sell to pick up something similar.
Old 05-12-2015, 12:59 PM
  #884
oscs's Avatar
Well the install hasn't happened yet.. However it is only .400" shorter than the T56 so i should be able to use my same Trans mount location. With that said there doesn't seem to be a mount location on the GV unit so it looks like i will be welding some mounting tabs on it.
As far as dollars go.. I hope your sitting down.. Glide was $4100 shipped with the converter. The GV was $3050 shipped. The true cost for me is almost 8k due to the fact that i still needed to buy a shifter/cooler/flexplate..
Old 05-12-2015, 01:06 PM
  #885
stevieturbo's Avatar
So what actual overall gear ratios has this given you for the trans ?
Old 05-12-2015, 01:09 PM
  #886
coltboostin's Avatar
Fak.
And everyone sells as Auto being a cheaper option than a T56? I guess than conv ends int he aftermarket.
Old 05-12-2015, 01:14 PM
  #887
Forcefed86's Avatar
Its the $4100 glide that has my mind blown. Figure you were gonna pay for the trans either way, so 3k instead of a solid rear end swap/fab ins't too bad IMO. I had $2600 in my 8.8 RX-7 swap kit. And that was installing it myself. Theres a shorty glide FS for $1200 local...has me thinking!
Old 05-12-2015, 01:19 PM
  #888
oscs's Avatar
Yeah im not terribly stressed about it. In the end it was a long term economical decision. The manual would have continued to destroy driveline parts and it would never be as fast. I justified the purchase with hopes of faster times/less breakage. Im trying my hardest to avoid a SRA swap. I would like to continue competing in "stock suspension" location classes. I already feel like a sell out with the auto much less going SRA.. There is still some cool factor that the car is still IRS. The big question is how long can i stay off the trans break.
Old 05-12-2015, 01:22 PM
  #889
Forcefed86's Avatar
.78 OD for each gear.
Old 05-12-2015, 01:25 PM
  #890
oscs's Avatar
Originally Posted by coltboostin
Fak.
Those people haven't done the math. A TOP of the line T56 super magnum will run you like 5500-6K. That aint **** compared to what some of these Autos get up to.
Old 05-12-2015, 01:30 PM
  #891
gnx7's Avatar
That trans is a work of art! And pricey.... ouch
Great shot in DSport magazine!
Old 05-12-2015, 01:40 PM
  #892
So top being a 1:1 and then 0.78...overall leaves it just shy of a normal T56 5th gear ?
Old 05-12-2015, 01:43 PM
  #893
oscs's Avatar
Pricey is right! But in my eyes there isnt a better option so im ok with dropping the cash this time. I don't think that pic made it into the magazine, I just found it on there website.
Old 05-12-2015, 02:56 PM
  #894
Forcefed86's Avatar
Pretty much, just rated for big power. Typical glide spread would be 1.76 - 1.37 - 1.0 - .78.
https://www.gearvendors.com/hrgm3s.html
Old 05-12-2015, 03:47 PM
  #895
rotary1307cc's Avatar
Its more like a 3 grand glide (minus converter) which is fair for an aftermarket case with a good gear set and aftermarket pump
I have maybe 1500 into my glide with a good gear set. But I have a stock housing and pump
Better add in the cost of the clutch for a t56
A t56 of any build quality is like glass compared to a glide with a couple parts
Old 05-12-2015, 03:58 PM
  #896
oscs's Avatar
Yup, I think the case was like $900. Still thought this is a relatively low level Glide. Ive seen them as high as 12K for some crazy ****. FTI rates it for 1200WHP but ive seen similar style glides hold 1500+
Even at $6500 for a clutch and a brand new top of the line GM manual trans.. that is a drop in the bucket compared to some autos ive seen. Also your right no T56 can hold a candle to a Glide.. all reasons why i made the decision to switch.
Old 05-12-2015, 07:46 PM
  #897
ajrothm's Avatar
The car will be much faster with the glide and the trans is 10x stronger then the best stick trans.... Definitely the way I would go, especially on a light car. The GV was a nice touch. Interesting combo for sure. If you could put a Fab 9 rear end in it, the drivetrain would be bullet proof.
Car is gonna be nasty.
Old 05-13-2015, 09:08 AM
  #898
oscs's Avatar
I hope so. I just switched to solid motor mounts/aluminum/teflon fuel lines (C16) and some solid motor mounts. I have high hopes for this car.
Old 05-13-2015, 09:26 AM
  #899
rorric's Avatar
With the glide you wont have converter lock up ?
Old 05-13-2015, 12:01 PM
  #900
oscs's Avatar
No i will not
Quick Reply: Twin Turbo LSX Datsun 280Z
