Twin Turbo LSX Datsun 280Z
#1144
#1148
I haven't adjusted alignment since i changed the whole rear end setup and it was -1.8 before as it was not a dedicated drag car. It doesn't really look like that in person though, The pictures make it look way worse. ill be going 0 or -.5 this weekend.
#1149
#1151
This is actually the oil pump for the dry sump system. It does have a provision for driving a mechanical fuel pump off the rear of it. Be pretty simple to put a Waterman at the back. You'd just have to use a front plate mount instead of the side motor mounts. This one is from A.R.E and is made to bolt to the LS blocks using a bot hole near the top front of the block and the 3 bolts holes one the bottom of the block used for holding the a/c. My dart block doesn't have the bottom holes, so they are drilled and tapped into the pan rails instead.
#1153
I was going to put a Waterman in the front cover of my 6.7 Cummins but it stuck out just a little too far and there wasn't room to move the radiator and intercooler any farther forward. Seems like a good idea though if they hold up over time.
#1154
I'm just so tired of electric pumps being inconsistent.. Im having FP issues at WOT so guess what i get to do this weekend.. Tear apart my fuel system and find out what the issue is..
#1155
Exactly what issues ?
I've had a pair of 044's in mine for about 10 years now, they've been solid the entire time, and that's with a less than ideal supply line from the tank itself
#1156
I think you'd rather work on your car than drive it. Not saying that's bad, just an observation. :-)
#1157
#1158
The build is enjoyable, but USING the car is always better!
Is it going lean, or are you just seeing the gauge bounce around a bit?
#1159
I just over think everything and constantly think how i can/could do it better. That often puts my car back on the lift. I defiantly DONT like working on it. Im assuming that some extended down time with E85 damaged the pumps a bit. the pressure spikes to about 50 on WOT and then drops to 30ish. I think one pump is going out and its back feeding into the other and no i dont have check valves
#1160
