Header ?
Old Feb 19, 2014 | 06:36 PM
6togo's Avatar
Default Header ?
I got a set of turbo headers which are SS 1 3/4" x 3" for my twin 427 build but the merge collector necks down to about 2 1/2" then to 3" is that going to cause any restrictions i should worry about?
Old Feb 19, 2014 | 08:57 PM
LS1NOVA's Avatar
Should have used 2.5 vbands on the collector and 2.5 hotside. The turbine is the restriction.
Old Feb 19, 2014 | 09:07 PM
T76s10's Avatar
That looks goofy looking. I agree you should cut those transitions off and run 2.5" v bands
Old Feb 19, 2014 | 10:26 PM
6togo's Avatar
I agree they look funny but would running the 3" v-bands that are on there cause any flow issues?
Old Feb 19, 2014 | 10:30 PM
T76s10's Avatar
No but 3" is way too big. 2.5" is plenty of flow. I wouldn't run a 3" hot side if it were me
Old Feb 19, 2014 | 10:43 PM
6togo's Avatar
The turbos are going to be very close to the headers so there is not much pipe to talk about before the T4 flange maybe 6" or so.
Old Feb 19, 2014 | 10:52 PM
5spd-iroc's Avatar
wouldnt you wanna run a t6 flange on a 427, like a s480
Old Feb 19, 2014 | 10:53 PM
5spd-iroc's Avatar
i guess not if your running twins
Old Feb 19, 2014 | 10:56 PM
6togo's Avatar
Old Feb 19, 2014 | 11:07 PM
garrysturbo's Avatar
Hi. , who made those turbo headers. I like them cause it seems shorter @ the collector compared to Stainless Works turbo headers cause I have the 70' Nova.
Thanks Garry
Old Feb 19, 2014 | 11:22 PM
pinkston.jon's Avatar
They look like Jardine's to me, but I'm just going off of pics since I'm in the market for some as well.
Old Feb 20, 2014 | 07:06 AM
6togo's Avatar
Correct they are Jardines these are a second set they made for me the first set were decent in quality but not perfect so they made a second set which are nice but have the funny collector the other set had a straight 3" butt type VS the 2.5-3" slip. The other set is still very usable just need cleaned up a little but they do tuck up tighter to the engine that's why i choose them!
Old Feb 20, 2014 | 07:56 AM
T76s10's Avatar
3" pipe can be squared out perfectly to fit a t4 flange. Since your doing twins right off the header you'll be fine. Sucks they didn't just do a 3" collector though.
Old Feb 20, 2014 | 08:22 AM
Thank you , how do I get ahold of Jardines , sorry , I've seen VA , SW & others turbo but not familiar w/ his. Again thank you & good luck on ur build !
Thanks Garry
I found him , thanks.
Old Feb 20, 2014 | 06:13 PM
6togo's Avatar
Jerod is a great guy to deal with he does what ever is needed to make sure the customer is happy!
Old Feb 20, 2014 | 09:03 PM
Thank you for the response.
Thanks Garry
Old Feb 20, 2014 | 10:21 PM
6togo's Avatar
Been talking with Jardine about the collector and he says that they will flow better than a straight 3" kinda have my doubts though.
Old Feb 21, 2014 | 12:11 PM
stevieturbo's Avatar
There was a video on youtube showing a simple test with a tapered merge collector. It basically assists scavenging much better than a straight tube collector. Cant find it though.
But this shows a little of what a good merge collector alone can do
edit... this is it. The fact turbo headers are under pressure doesnt matter, same rules apply.
Old Feb 21, 2014 | 04:16 PM
Noahf's Avatar
thanks for those videos stevie, that 2nd video was awesome
Old Feb 21, 2014 | 04:19 PM
Was surprised myself when I seen it, a very simple but effective demonstration of why collectors are good, and why a tapered merge is even better.
