F1c head unit bracket question
Old Feb 23, 2014 | 10:40 AM
LSX-PWR's Avatar
Default F1c head unit bracket question
Hello guys I just purchased an 08 regular cab silverado i already have the Procharger system for the truck with the D1sc head unit. With that said I want to replace the unit with the F1c. Can I still use the stock brackets that came with the system? Or do I need to purchase a diff bracket set up? If so where would be a good place to purchase one?
Old Feb 23, 2014 | 11:49 AM
stmz28's Avatar
you can use the same brackets
Old Feb 23, 2014 | 12:21 PM
LSX-PWR's Avatar
That's good to hear. Now I need to sell my D1sc setup and order the new one. How street able are the F1x?
Old Feb 23, 2014 | 06:16 PM
NemeSS's Avatar
how much for d1sc?
Old Feb 24, 2014 | 08:09 AM
I8UR4RD's Avatar
f1-x would be fine on the street as long as you could find something to hold it. Schoneck Composites makes a cog bracket for f body that will hold it. the F1-C is still an 8 sec capable blower in the right combo. strauss goes 7's with his F1R and a glide.
Old Feb 24, 2014 | 10:11 AM
LSX-PWR's Avatar
Not sure on how much the d1sc are going for? Make me an offer. As for the F1-x that sounds like a great blower but like you said if I can find a bracket.
Old Feb 24, 2014 | 10:10 PM
Bob@BruteSpeed's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
What is your engine combination? An F-1A on a 408 can make 18 to 20 psi which is all an aftermarket set of four bolt heads can handle. An F-1C takes a little more power to turn it than an F-1A, although it wouldn't be worked as hard at 18 to 20 psi. I wouldn't try running anything larger than an F-1A with the stock 6 rib bracket assembly. If you have a six bolt block and head combo then you could handle an F-1X but you're going to need a cog bracket. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old Feb 24, 2014 | 10:25 PM
LSX-PWR's Avatar
As of now I'll be running a 416 ls3 short block with TSP LS7 small bore heads with a Holley high ram and NW 102mm tb. Although I have a LSX 427 being built.
Old Feb 25, 2014 | 12:01 AM
Blown06's Avatar
8 Second Truck Club
How much power are you trying to make?
Old Feb 25, 2014 | 04:44 AM
LSX-PWR's Avatar
Old Feb 25, 2014 | 04:58 AM
LS1Tech Sponsor
http://shop.brutespeed.com/LSx-Trans...ce-Kits_c8.htm
The ProCharger Transplant cog bracket assembly is probably your best way to go. No belt slippage and you could start with an F-1C, and upgrade to a larger head unit down the road. Bob
__________________
Old Feb 25, 2014 | 09:10 AM
LSX-PWR's Avatar
Thanks Bob for the info. I have a complete 5th gen camaro pulley set up. I bought a complete ls3 transplant.
Old Feb 25, 2014 | 10:34 AM
LSX-PWR's Avatar
Bob if you could please pm me a price on the 8 rib conversion for my D1SC. I'll use this for now while my 427 is done. Thank you
Old Feb 26, 2014 | 12:28 AM
Blown06's Avatar
8 Second Truck Club
LSX Transplant Cog Kit in a truck for the win
Old Feb 26, 2014 | 02:15 AM
LSX-PWR's Avatar
Now that's a set up!!!
Old Feb 26, 2014 | 03:12 AM
Ws6Dnero's Avatar
Is your d1sc reverse rotation?
Old Feb 26, 2014 | 08:36 AM
LSX-PWR's Avatar
It's a type b from my understanding. Intake side is towards the headers.
