Mounting small twins on the side of the engine. Pictures?
The car, 1996 Z28, turbo'd these last 8 years with a 76mm single turbo.
I know that INTMID8 had an LT1 at one time that had twins on either side of the block.
Anyone have pictures of that or a picture of their own setup? I'm trying to evaluate that setup vs the one in the battery tray, one on the other side setup. I have the turbos already (GT35's 61mm. .63 A/R) and will look at my options. If I mount them on the battery/air box opposite sides, I can use my current hotsides headers which exit in front, near the rack n' pinion. I'd just add some risers to go up to meet the turbos. If I went to the sidesaddle, so to speak, mount, I'd weld up some log manifolds.
I'm fairly certain the side mounts would require an oil return pump since they'd be mounted so low. Plus my current return for my PT7675 is at the front of the Canton oil pan. I have the two wastegates already and my FMIC has been on the car since 2008 or 2009. I have plenty of Intercooler piping/couplers and quite an array of 3" mild steel for the rerouting of the hotside.
I would look at Boo"SS"t's build as well. It's an LS1 car but he mounts the turbos very similarly to how you want to. Always good for ideas anyhow. He's certainly given me plenty of bad ones and is the reason I have a hacked up set of 2010 manifolds on my old LS1 block in the garage. lol
https://ls1tech.com/forums/forced-in...manifolds.html
PS. I thought you were mailing the GT35s to my house?
I don't know if you've seen my other thread about my fuel injector box issues but I *think* I've found the cause. Hoping to put the 95# back in the car. The 60# I have in there now are maxing out when I run 19psi. I've been as high as 21psi a couple of times. Right now, when I run at 15psi, the A/F ratio is 12.2 in 4th gear near 6,000 RPM.
Thanks for the pictures. Looks great!
