317s vs ls3 heads on 370 procharged
Old Jun 30, 2014 | 08:41 PM
speedfreak2685's Avatar
Default 317s vs ls3 heads on 370 procharged
I've did some research but didn't see much comparing the 2 with boost. Im building a somewhat budget build 370 with a D1 procharger spinning at its max. I'm looking to maximize the bottom end as most cost effective as possible. I already have a set or 317 heads but they will need cleaned, checked and a valve job at minimum. ive also seen ported ls3 heads sold by vendors for roughly $1300ish. Either way i have to buy a cam to compliment either and the valve train to match the setup. I know the 317s are proven heads but would spending $1300 on ls3 heads really gain me much on a boosted setup over the 317s?
Old Jul 1, 2014 | 12:59 AM
Blown06's Avatar
8 Second Truck Club
If your gonna make the move to ls3 style port. Check out the lsa's.
Old Jul 1, 2014 | 02:24 AM
coolmanvette75's Avatar
Agreed. That is what I am running
Old Jul 1, 2014 | 07:13 AM
Bob@BruteSpeed's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
The LS3 style ports flow much better than the 317 ports do, there is no comparison. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old Jul 1, 2014 | 07:17 AM
LS1Tech Sponsor
I agree! Bob
__________________
Old Jul 1, 2014 | 07:31 AM
jleews6's Avatar
I have never done a comparison but like they said the LSA should make more power. Take a look at how much more they flow and now think about how much more they will move at 15 pounds.
Old Jul 1, 2014 | 04:33 PM
can someone point me in the right direction of a vendor that sales lsa heads?
Old Jul 1, 2014 | 04:53 PM
SCott5's Avatar
Lsa heads for sure
Old Jul 1, 2014 | 07:54 PM
burbalanche's Avatar
Not trying to high jack ur thread but as i am gonna be building a 370 also and already have a set of ls3 heads i didnt have to spend money on but my next question im trying to figure out is either finding a stock intake for it again or is it worth spending money on like a holley high ram?
Old Jul 1, 2014 | 08:34 PM
LS1Tech Sponsor
The LS3 intake does a good job, but more power can be found with an aftermarket intake. I guess it would depend on if you already have an LS3 intake and what your goals are. Bob
__________________
Old Jul 1, 2014 | 09:07 PM
97WS6SCharged's Avatar
OP. From a cost/performance stand point if you already have the 317s use them. If you have an extra $1300 to blow on heads then send the 317's to AI and have them ported.
Old Jul 1, 2014 | 09:10 PM
I only have stock 6.0 intake and running ls3 heads i have to get a new intake either way so trying to figure out wat would be a good one to get? The holley or any others? Will be running e85 th400 fi s480 probably and in a roughly 5000lb truck. Power wise idk say 7s ?? Thanks
Old Jul 2, 2014 | 10:09 PM
yonerhottlt1's Avatar
I found a set of brand new LS3 heads on here in the classifieds section for $675 shipped. LS3 heads in stock form should still outflow a set of ported 317's. And The LS3 intake manifold also moves a ton of air in stock form and they're cheap.
Old Jul 3, 2014 | 07:13 PM
I tried finding the thread with no luck.
From what I gather, lsa heads are the best and strongest but ls3 heads will do fine for my power level (under 900) and regardless will be a step up from my 317s. Sound about right?
Old Jul 4, 2014 | 04:59 AM
LS1Tech Sponsor
Yes indeed, a huge step up from the 317 heads in cfm. Bob
__________________
Old Jul 4, 2014 | 06:43 AM
I8URLS1's Avatar
My buddy makes 1190whp on BONE STOCK ls3 heads & intake with a precision 8891 and standard size head studs. All I'm the tune and packing the right cam to make sure your cylinder pressure is where it needs to be. If you can find LSA heads for a good deal go that way, I would buy either one however
Old Jul 4, 2014 | 04:00 PM
2000RATA's Avatar
Originally Posted by I8URLS1
My buddy makes 1190whp on BONE STOCK ls3 heads & intake with a precision 8891 and standard size head studs.........
Those are impressive numbers! At what boost pressure is that 1190 achieved? You are correct that the right can and tune is key!
Old Jul 4, 2014 | 04:06 PM
Firehawk441's Avatar
Originally Posted by Bob@BruteSpeed
The LS3 "STYLE" ports flow much better than the 317 ports do, there is no comparison. Bob
Old Jul 4, 2014 | 05:39 PM
I8URLS1's Avatar
19-20psi
