LSx Budget Dyno Queen. Ls1 Rx7+turbo(s)
Old 07-27-2015, 08:57 PM
  #341
jleews6's Avatar
Looks good man. I have to say though I still think that drop to 5th gear is really going to drag it down. Get the gear changed and its going to fly.
Old 07-27-2015, 10:30 PM
  #342
coltboostin's Avatar
It does. Its brutal. There is just no true bolt-in options for this car that dont cost a million dollars, so I have to Fab up somthing this winter.
Its #1 on the to-do list!
Old 07-28-2015, 03:00 PM
  #343
Tjabo's Avatar
Damn, that's looking like it is going to be a fine ride! Way too good for me to thrash on, I hope you can still have fun ripping up with it.
Old 07-28-2015, 09:08 PM
  #344
krazy4's Avatar
Do you want to keep it IRS?
Old 07-29-2015, 08:15 PM
  #345
1320king's Avatar
Do this and never look back!! Best 2k I ever spent! And was able to sell my T2 diff and axles for $500 so $1500 technically well spent
Old 07-30-2015, 09:23 AM
  #346
Thats my fear-I have never babied the car. Now, I feel like I kind of have to!
I think that would be my preference as I would like to road race the car next year as well
That looks great!! Still not sold on going Solid axle quite yet though although the weight loss would be nice...you did that yourself right?
Old 07-30-2015, 12:16 PM
  #347
1320king's Avatar
Pretty much. Took a foxbody mustang, made a jig with all the mounting points from the factory 4 link setup. Than transferred it over to the rx7 using chromoly tubing and some beefy adjustable brackets. I have a good friend that does chassi work. Hooked it up big time! Also lucked out and bought a fully built moser rear with 35 spline spool, axles, 9" ends, brakes etc etc for $800
Old 07-30-2015, 03:25 PM
  #348
Awesome!
Old 08-04-2015, 10:51 AM
  #349
I have to admit, I cant believe I own this thing!!! Super happy with the outcome.
Next up-finalize the intake. Hopefully it is an improvement.
I would also like to get 340's in the tank so I can safely run 20+psi in 4th and 5th and see what I can get out of the 4.10 rear gear. If I take 4th to redline, its still falls quite flat on the shift to 5th, but I am sure the increased boost will help that issue.
Old 08-04-2015, 11:40 AM
  #350
Tjabo's Avatar
Damn, that looks SWEEEET!!!
The visible flex pipe is hilarious.
Old 08-04-2015, 01:35 PM
  #351
She has a pretty face now, but is still a sloppy girl at heart.
Old 08-05-2015, 01:09 PM
  #352
1320king's Avatar
My fave type
Old 08-05-2015, 02:30 PM
  #353
Nismo Kid's Avatar
Your car came out great man.
Old 08-11-2015, 11:02 AM
  #354
Thanks guys!
So this weekend was the DSM shootout. If you guys have never been, make the trip! The Fastest GTRs and Mitsubishi powered vehicles in the country come out every year for this.
Car show and dyno day Friday
Race Saturday/Sunday. Unfortunately since the car is not a Mitsu or GTR, my run time was super limited to TnT
Here is how the runs went-all runs at 17-18psi
First run-good launch-car is shutting down every shift. Feel like fuel slosh, but I have 5 gallons in the tank? 10.8@128. Also noted wide band was DEAD. Great, guess I am not turning it up. :-[
Put 4 more gallons in and take it out for a test hit- problem is GONE. Must have been shosh!! Man I need a sump!
Second run-roll out 1st and hammer down-car is all over the place but running well. Not thinking, I short shift into 5th AGAIN, and I have ZERO psi (the car was actually violently surging between 0 and 5 psi) so I toss it in neutral and coast through the traps....to a 10.3@136. :banghead: That was my 9!!!!
Next pass, I let her have it off the line, and snapped the drivers side axle. As a reminder, this is an NA LSD, so I am shocked it lasted this long as is!!
Fixed the axle, and TnT was closed. They would not run it the rest of the night! Partied the rest of the night, and drove home.
I can say I have never been more disappointing to run a low 10 second pass in my life
Here are a few vids. the 10.8 slosh, and the 10.3 coasting through the traps in neutral. Sorry for the facebook link, I have asked the camera man to upload to youtube.
Facebook Post
I was so annoyed that I botched that run, I wanted to see what 20+psi was like on the street. The car goes lean on the dyno in the upper RPM's over 20psi and my wideband was dead, but I didn't care. Maybe it was my pride? Maybe it was all the pork and beans from the PR track crew? Maybe it was the Coronas? Who knows, but that LS1 was in trouble.
When I was within 10 miles of home, I pulled over and gave the MBC a few cranks, here goes nothing! Test hit spiked just past 20psi. Like it So I slowed down to test a 40 roll. 40 in 2nd was 100% useless-I just buried the limiter. Lets try 3rd, more of the same. So I decided to do a 4th gear roll on.
It spun so violently that the car almost came around me at 100+. I had to lift and use the next 2 lanes over to get it sorted out. Glad It was 5am! I did a 3-4th pull with my foot controlling boost and let her have it in 5th. ****. I wish I had the Vbox because that was ridiculous.
Noticed the car was getting warm on my exit, but there is NO one out, and a mile of Blacktop before my street. So, I did what every other hooligan would do and did a 1-2-3-4 rolling burnout. By the time I got home, coolant temp was pegged at 250+. I may have tweaked the HG, but Im not worried. It gives me an excuse to but a HG, studs, and springs in it so I can spin it to 6500 and hopefully alleviate my boost drop issue going into 5th.
What a night!
Old 08-11-2015, 01:20 PM
  #355
Forcefed86's Avatar
That poor little engine...
Probably cheaper/easier to pick up an ebay surge tank. Feed it with 1 intank 255. Then run dual 044's off the tank so you don't lean out.
Old 08-11-2015, 02:17 PM
  #356
That's the plan. Only question is if I will ever run E85, in which case I may want to get the factory tank our of the system all together. We will see.
Any NHRA rules about having the tank and pumps in the engine bay? The car will likely never fit in class that I will be "tech'd" into, but its good to know. I have a TON of room up front, so I planned to set things up there.
Old 08-11-2015, 02:40 PM
  #357
1320king's Avatar
If i remember correctly nothing can be mounted to the firewall but other then that your good to go.
Old 08-11-2015, 03:06 PM
  #358
That would be grand!
Old 08-20-2015, 11:21 PM
  #359
One of the top Media guys in the DSM community took great video of my junk at the shootout. I know I'm working to get the car down the track, but this looks rediculous lol
https://www.youtube.com/watch?v=KNtP...ature=youtu.be
This shows just how bad the car was fuel sloshing the first few passes-and you can hear me shut it down up top on the 10.3 run.
Its all learning-but I've got a lot of work to do to actually use the power the car is making.
Old 08-20-2015, 11:27 PM
  #360
Project GatTagO's Avatar
Received 1,485 Likes on 929 Posts
This shows just how bad the car was fuel sloshing the first few passes-and you can hear me shut it down up tom ont he 10.3 run.
What kind of front tire are you running? Can't quite tell in the video.
Andrew
Quick Reply: LSx Budget Dyno Queen. Ls1 Rx7+turbo(s)
