Alternator Relocation with Auto Tensioner?
Driving down the road the other day one rib from the belt came off... So I'm wondering if there is any kit or way to run the alternator up there and still use a spring loaded tensioner system?
What I'm getting at is the fact that the setup doesn't use a tensioner is not the reason for your belt failure.
Is you belt alignment ok?
I know as I was working on the tune for the car, a few issues were causing it to stall and when the engine died i could hear the belt squeal.
Thanks for posting the pic's! I like to see what guys are putting them on.
Looks like you got that super charger locked down good tying the J bracket to the motor plate.
To GRP, could post a pic or two of your setup? We may be able to help you find you problem.
I already have the alternator mounted up high. If i could add a tensioner by bolting it into the system some how that would be great and I think solve my issues.
the serpentine pulley Under the power steering pump is Just the Original F-body Alternator Bracket
I still needed it for my belt routing
and yes... My Procharger Setup is Completely Custom
Designed by me.....
pretty much everything on the car is Custom...LOL
for my Procharger Cog Belt Tensioner
theres a block on the back side that the pulley is mounted to.
and a block with threads and a Stud with and Allen Head beneath that
the stud pushes up on the block attached to the Pulley
theres also a nut welded to the bracket standoff so that I have something to stabilize the stud and to be able to use a locknut to lock the stud in place
once I get it where I want it, I lock the stud with a nylon lock nut and I tighten the pulley bolt up to suck it in against the plate...
there is a small spacer on the back side of the pulley to keep it from touching the plate so it can spin freely
I used the pieces off of a Small Block Ford F1 Bracket....
Block, Pulley, spacer....
then I bought an allen head stud to use since I needed a different style bolt than the Procharger kit had
(I had originally bought the Supercharger and a SBF Bracket from somebody with no intentions of using the bracket...I bout it at a steal, and it just happened to have some extra pieces that I ended up converting to use on my bracket)
this is everything minus the CBR Alternator relocation Tensioner/Bracket and my Vacuum Pump
