Boost by speed control - sensor hook-up to Holley HP
I really need help though getting the sensor to work .I'm trying to use the front anti-lock wheel sensor on this Mustang and 50 tooth reluctor. Its a 2-wire sensor, magnetic I think which puts out a sine wave. The Holley HP will only use a Hall-effect sensor/square wave. Is there a simple converter that I can use to get this to work??
And make sure you reference speed of an undriven wheel or GPS
No sense having boost rise with speed...and speed is measured of driven wheels that might lose traction...which would potentially offer more boost.
I would see no sensible reason to try and introduce boost steps, when you could have a smooth rise of boost, hopefully keeping you on the edge of traction.
http://www.summitracing.com/parts/msd-8509
Also bare in mind though, if you are wishing to retain ABS, piggybacking anything on top of a factory sensor can make the ABS unhappy
http://jbperf.com/dual_VR/v2_1.html
The MSD thing you linked should achieve a similar thing.
Not sure if you have the cars over there or not, Vauxhall/Opel Astra ? GM product, small 2/4 door hatch
These actually use a small yellow relay which isnt a relay. It actually does the same thing. Converts a VR signal to digital.
See this thread here, with some pics.
http://www.syvecs.com/forum/viewtopi...6&t=553&p=2809
Thanks for the links!!!
Boost by gear I believe is looking for an rpm drop to "assume" a gear change has been made. What if you lift the pedal a bit due to spin...I would think that would screw everything up - just a guess.
If the controller is "assuming" gear...then it simply is not capable of boost by gear, so speed is the easiest option.
Too many controllers seem to claim boost by gear, when the reality is they're full or **** making assumptions as to what gear you're in by some sort of rpm drop, sequential switching or other nonsense which never truly determines gear
I'd say that overall boost by gear is a better option. Largely because it will still allow you to make use of the torque from the turbo in any gear.
Whereas speed based, if you were cruising at 4th or 5th at lowish speed for example you would never have access to that same boost/torque because you'd be at a lower speed.
Likewise for a more aggressive lower gear, not possible because your low speed.
There are compromises either way, but also advantages. Up to each user to make the most of either option.
Ramping boost with rpm, gear and throttle compensations can make for a very good package.
If you can also program multiple boost maps based on the above also selectable via a switch....then you have a very versatile setup for a variety of conditions, traction levels, uses etc
