Turbo + Nitrous
Old May 25, 2004 | 02:44 PM
Abidar's Avatar
Default Turbo + Nitrous
I know this is not what most of you are expecting. This is actually a question... unfortunately not my setup.
I was wondering, I know nitrous on top of a turbo can have good cooling/ power effects, but everything I've ever read about it isn't any more specific. I was wondering whether the power gains were expontenial due to the decrease of temperature? Or is it just like spraying nitrous on an N/A engine? How much nitrous is possible with a forced induction setup with all the forged goodies? Could I run twin turbo at 15-18 psi with 100-200 shot of nitrous? Maybe nitrous on on top of 15-18 psi is overkill...
Anyway, thanks in advance.
Old May 25, 2004 | 03:44 PM
ChevyNo1's Avatar
From what I understand a 50 shot on an FI setup will be worth close to 100 when all is said and done . . . basically almost double advertised.
Old May 25, 2004 | 03:55 PM
Tiago's Avatar
On the prototype turbo grand prix we went from 320 rwhp non intercooled to 430 rwhp on a ~50 shot dry 12 psi, stock motor.
Old May 25, 2004 | 05:50 PM
Abidar's Avatar
That's what I was thinking. Do you think it increases as hp/tq rise? Like 1.5 times or 2 times the advertised "shot" if I were making 700+ hp?
Old May 25, 2004 | 06:10 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
If you do pursue a setup like that you will need to take out more timing.
Old May 25, 2004 | 06:18 PM
Abidar's Avatar
Also, is that a dry or wet shot?
Old May 25, 2004 | 06:51 PM
Abidar's Avatar
Tiago, checked out your website. FRIGGIN AWESOME! I couldn't pull up the links for the LS1 kit though. Also, do you fab twin setups?
Old May 26, 2004 | 08:15 AM
Tiago's Avatar
LS1 kit is still coming to life, but the website is being refreshed currently
I fab anything a customer wants to do. A dry shot injects nitrous only and a wet shot injects both nitrous and fuel into the motor.
Old May 26, 2004 | 08:35 AM
parish8's Avatar
single digit dreamer
turbo and nitrous together are cool
i would think on a non intercooled set up the nitrous would have a bigger effect. if you have a killer intercooler than i doubt you would see the doubling effect.
Old May 26, 2004 | 08:45 AM
kp's Avatar
kp
with 2 x .024 jets (50 shot) I'm seeing around 60rwhp on the dyno. I am shutting it off at 5900rpm though so with more boost it may make more of a difference, thats with 80 degree IATs and 1000psi bottle pressure on a dry kit.
Just waiting for my roll bar to get some track times, its hard to see whats really going on with a loose converter on the dyno - feels good driving it though
