58 tooth or 24 tooth reluctor wheel?
The two will make the same power. More aftermarket engine management systems can understand the 58x crank wheel (60 tooth less two teeth) but several aftermarket systems can understand the 24x wheel now.
If you want to be able to go to mechanical throttle using OEM electronics then you want the 24x reluctor wheel. None of the GM ECM's support mechanical throttle and 58x. On the other hand you can do electronic throttle or mechanical throttle with the 24x reluctor wheel.
If you want to control an electronic transmission you can get a single module (a Powertrain Control Module, PCM) to control the engine and transmission. With the 58x crank you will need an ECM and a TCM.
On the other hand if you want to run the newer 6spd automatic transmission (6L80 or 6L90) then you will want a 58x crank because the T43 TCM that controls those transmissions is normally combined with a E38 or an E67 ECM (both 58x ECM's).
Lots of other small plusses and minuses exist for each but in the end you can make either one work in most custom applications.
Hopefully some of that information is useful and I haven't made this more confusing.
The 58 has the benefit of a 4x cam sensor to go with it.. which equates to a faster start..in as short as 1/4 revolution instead of a full revolution with the 1x cam sensor and the 24x crank.
I have a 24x crank in my engine.. because I had an ecu that had a 24x operating system.. now I have a Holley EFI system... and it no longer matters which one I use..
Both of them work equallly as good..
My car starts instantly.... and I spin it 8000 rpm on a regular basis with zero issues....with a 24x reluctor and a 1x cam sensor...
the failures of a few does not equate to a common problem
plenty of people going fast with a 24x reluctor.
But that's hardly a good argument for going back to them.
That still doesnt mean it's a good system when you know there are better options.
