Found someone crazier than Harlan - 8 turbos?
LS1Tech Co-Founder
Yes, you read that correctly. This guy is building an LS1 powered '57 Chevy, with eight!! turbos on it.
WHY? Surely couldn't be for performance optimization, probably just cool factor.
http://www.lateral-g.net/sandlin/
Originally Posted by Excal
thats a prety crazy set up, can't wait to see what it looks like when they get done.
WTF........C5R powered aztek http://www.lateral-g.net/aztec/
check out the dual intake manifold like a viper/lambo
Adkoonerstrator
The 8 turbo engine ran great on the dyno. Built boost fast and held steady throughout rpm band. Had a cool sound when you shut the throttle after a run. It was a crazy site to see!
The Aztec project started life as a drag build with the C5R 427 engine and a turbo 400 backed by a 12 bolt rear axle. About two months into the build it changed to a road race build so the 400 turbo trans made way for a 6 speed manual. It is very good handling and has good straight line power but its never been on a dragstrip yet.
Kurt
Kurt
