Scrapyard S10
Old Jan 18, 2018 | 09:45 PM
  #221
dmaxs10's Avatar
Just skimmed this thing looks sweet, will have to read it later. I don't know why but I find it really funny that leaf spring bent, ok 4 link time!
Old Jan 19, 2018 | 12:47 PM
  #222
tblentrprz's Avatar
Originally Posted by Cyrperformance
Yes!! The weak link was listening to someone else who told me to remove the middle leaf. I should have looked into doing this and found that no one removes the middle leaf in a three stack setup!!!!
Likely would have been OK if the traction bar was longer like caltrac and front mount by front bushing.
Old Jan 19, 2018 | 06:15 PM
  #223
Cyrperformance's Avatar
They were long, the snubber was just behind the front leaf mount. They bent on the first run and completely snapped off on the second launch. Launched it a couple of times kinda soft on the small road behind our building and it has quite a bit different feeling with the four link. And everything is still where it should be!!
Old Jan 19, 2018 | 06:16 PM
  #224
Yeah I should not have listened to that goon, but can't blame anyone but myself. 4 link is done!!
Old Jan 19, 2018 | 06:23 PM
  #225
Originally Posted by BudRacing
Funny that you got lined up against a GLC300, haha! My wife has one. Honestly, it's a lot quicker than I expected a 2.0T to be in a small but still heavy SUV. The transmission does the platform a lot of favors. Any idea what it ran? I would guess 14's.
It was funny cause the lady driving was late 60's and had her 3 grandchildren in the car with her!! That thing moved good for a grocery getter!! It was 1/8th mile but she drove it out the quarter as hard as she could and then tried racing me back to the timing people!! Have no Idea what it ran though. I ran a 7.45 @ 102mph spinning the entire way which is crap I know but went from a 1.826 60ft to a 1.589 60ft with new tires and leaving soft around 3lbs of boost. Next time out looking to leave on 6-8lbs for the first run and go up from there. would like to get to about 12lbs of the line and roughly 18lbs across the line.
Old Jan 19, 2018 | 08:03 PM
  #226
fastlt1's Avatar
New suspension
Fabricated a 4link
And picked up some cheap coil over kit
on the front 4 link mount. What did you attach it to. Got anymore pics
Old Jan 19, 2018 | 08:05 PM
  #227
At the front?
Old Jan 20, 2018 | 11:45 AM
  #228
tblentrprz's Avatar
That 4 link looks like it's going to work great with lot's of adjust-ability to dial in the 60.
Old Jan 20, 2018 | 05:42 PM
  #229
Thanks! Hopefully it helps with something!!
Old Apr 14, 2018 | 07:14 AM
  #230
Raced for the first time at the Quick 8 in Sebring International. Qualified 8th so had to run 1st qualifier in 1st round. Turn it up!!
Qualifying round pass on 7lbs
First round pass against #1 Qualifier.
Old Apr 14, 2018 | 07:18 AM
  #231
Here is a video of the qualifying launch.
https-//www.facebook.com/dean.engelhard.5/videos/1640690249348803/
Old Jul 10, 2018 | 08:47 AM
  #232
Got our first win on June 2nd!!!
Old Jul 10, 2018 | 08:55 AM
  #233
Old stock suspension setup.
And new suspension all done. About 80lbs lighter, much softer and rack and pinion. There is a ton of room up frontaround the engine now instead of everything smashed together!
Old Jul 10, 2018 | 09:30 PM
  #234
dmaxs10's Avatar
Very nice. Where you get the rack and pinion from?
what's up with what looks like water lines running by the trans in the pic?
Old Jul 10, 2018 | 09:35 PM
  #235
It's an IFS kit for a 56 GMC pickup that I've had laying around. The radiator hoses run to the bed where radiator is mounted. Those flex hoses are coming off and the aluminum tubing that runs under the cab to the bed will extend to the front with silicon bends to attach to engine.
Old Jul 10, 2018 | 09:38 PM
  #236
New stance
Sittin low and no more pan hanging below.
Old Jul 10, 2018 | 10:05 PM
  #237
dmaxs10's Avatar
I would love to see more of the rad set up. I was just thinking about that this week.
Old Jul 10, 2018 | 10:41 PM
  #238
I'll get a couple of pictures tomorrow and put them up. Pretty simple.
Old Jul 14, 2018 | 12:45 PM
  #239
Old Jul 14, 2018 | 04:35 PM
  #240
Bad Apache's Avatar
If you get a chance, check your inner tie rod clearance with the wheels turned and suspension compressed. I had to notch the frame slightly on mine. Easy peasy!
