What are my options for my AC box? (turbo build)
I've removed my AC but I wanna retain my heat and at least be able to blow a cool breeze in cooler weather, inside the car, or turn heated defroster on or somethin.. But I need to get the air portion of the box out of the engine bay. I painted all around it, as some may have seen in my build thread..
I really didn't wanna pull the dash.. Like, REALLY don't wanna pull the dash. So what are my options?
It isn't that bad.
You cut off the part going into the bay and then modify with some thin sheet metal to block it back off.
Seal it back up.
Reinstall.
There is a write up I used on here.. Think chrs1313 did it. Great info and good pics. I was a bit intimidated going in, turned out perfect.
You're pulling the dash. LOL
It isn't that bad.
Seal it back up.
Reinstall.
It isn't that bad.
Seal it back up.
Reinstall.
This was the worst part of my build. The dashboard engineers really know how to pack 10#'s of **** in a 5# bag. I'm glad I did it, turned out great, heat controls work just like stock. Passenger side spark plugs are easier to change than the drive side now, but i wouldn't want to do it again any time soon.
That's how I did mine. Start with a small hole and just keep cutting it bigger. The only thing in the box section extending into the engine bay is the evap coil for the ac and you're demo'ing that anyway. Trim it back flush, and trim/touchup the air path a bit and you're 99% done.
i used this and did mine.. Turned out awesome.
https://ls1tech.com/forums/drag-raci...till-keep.html
here is a kit i made years ago, still have a few copies of the parts.
its a no cutting of the box version
click for full size image
