alloy 5.7 block, high comp and boost
he told me he is running his 408 with twin 66mm borg warners at about 11.8:1 or so ( the thing is an animal that will light up the rears after he has put 4 or 5 car lengths on me while he is doing around 160 km/hr ( excuse the aussie measurements) ) now he is running an lq9 block, obviously much stronger then my ls1, but im looking to find any body out there who has done this before, and how it ended up for you?
I would only be looking to put around 10 - 15 psi in, and run it on e85
That isnt to say it couldnt be done and you may make it last for a while. But it is a lot to ask with the thin liners.
At the end of the day what is more important to you? Reliability or max effort? That will tell you what to do with your CR
Tread lightly.
i did have a thought this morning of sleeving the block, the rest of the bottom end is forged so it shouldn't have any issues, but if i do that i may as well just decompress the engine anyway once it is pulled down that far. i like the alloy blocks as far as weight saving goes as they are a heavy enough car to begin with and i dont really want to spend the cash on a new engine anyway, this one has enough of my money in all ready. So who's in favour of sleeve's??
I sprayed my 11:1 6.0...on top of 10# of boost
But it was also on 116 and the plugs still didn't look ideal
On a race care, sure, it could be tuned for a decent amount of boost with a good fuel and that compression ratio
If it's something you drive on the street a decent amount, make highway pulls in, idle in town getting warm, etc, I'd take the peace of mind and larger tuning window the lower compression ratio gives you
