Track update
Old Oct 9, 2015 | 04:42 PM
69-chvl's Avatar
Default Track update
Took the Stang to the track and ran:
60.........1.77
330.......4.59
1/8........6.90
mph...106.33
1000.....8.90
1/4......10.58
mph...133.33
This is a stock 5.3 with a 216/220 cam, 16.5psi in high gear, 14* of timing. 93 octane only. Only left with 1.5psi...I'll work on that. Does the mph sound about right for 16.5psi? Converter slip was around 8.5%. Overall happy with the way it was running.
Old Oct 9, 2015 | 05:31 PM
chiaj144's Avatar
What does it weigh? My 3200lb fox body went 135mph at 12psi with only 12*. Mine was a stock L33, valve springs only.
Old Oct 9, 2015 | 06:26 PM
69-chvl's Avatar
Not sure...from my research it seems that the V8 sn95's are like 3400, I'm 200 so 3600? Was the 3200 with you in there?
I also ran through a full 2.5" dual exhaust which may shave some mph.
Old Oct 9, 2015 | 06:38 PM
JoeNova's Avatar
Restricted User
I'm excited by these results.
I have a 5.3 L33 with a 218/218/212 cam, billet S475, 4L80e, 8.8 rear with leaf springs and caltracs. I've ran it at 20 PSI a couple of times. I think its about 200-300 lbs lighter than your mustang. Gives me high expectations for my times knowing you did so well at your weight and boost level.
Old Oct 9, 2015 | 09:36 PM
chiaj144's Avatar
Lightbulb
Yes 3200 with me in it. Through a full 3" exhaust, air filter etc. What was the DA? I'd say yours is on par with other 5.3's.
Old Oct 9, 2015 | 09:43 PM
69-chvl's Avatar
Apprx 850', so it was a good nite. I'd like to try a cut-out and maybe shifting a little lower...I was shifting at ~6300+, but looking at the datalogs fuel consumption peaks around 6100 and then starts dropping slightly after.
It might be heavier than I even think with that damn s475 in there, i/c and charge piping, 2 wastegates, DS loop and full dual exh. Need to find some scales.
Old Oct 9, 2015 | 11:42 PM
ajrothm's Avatar
Solid numbers Vince!
Get that sucker to leave and you'll be bottom 10s for sure...
Old Oct 10, 2015 | 07:21 AM
69-chvl's Avatar
Yeah gotta lean on her a little harder off the line for sure if I want the ET to come down. I'd love a 1.4 '60 but will settle for a 1.5!!! A dyno tune probably wouldn't be a bad idea either.
Old Oct 10, 2015 | 07:35 AM
RonSSNova's Avatar
Finally some encouraging results Vince!
That's more like it!
You have a two step function right?
And I bet it will like a cutout.
Ron
Old Oct 10, 2015 | 08:36 AM
69-chvl's Avatar
Ron
Yes 2 step was activated I just didn't have the pedal mashed down enough (I heard the turbo spooling so I thought I was good but evidently not)
Just need to find room to install a cut-out. I have the cut-out sitting on the shelf.
Old Oct 10, 2015 | 11:31 AM
RonSSNova's Avatar
Yeah, takes some getting used to. Basically just floor it on the two step.
Old Oct 10, 2015 | 05:23 PM
Ratical's Avatar
Nice times! Any day you can race a car and it comes home under it's own power is a good day.
Old Oct 11, 2015 | 11:40 AM
Forcefed86's Avatar
Cruise by the dump or truck station to get a weight, it will let you know if it's down on power. 3600lbs is pretty heavy, I'd be surprised if it weighed that much.
Old Oct 11, 2015 | 09:15 PM
69-chvl's Avatar
3600 does seem heavy, but again everything I've read points 3300-3400 for the car. I will try and find a scale.
Does 133mph seem light though at 16psi? The last 5.3 with the LS6 cam did the same. Been meaning to try running w/o air filter to see if that would make a difference but don't have the ***** to run w/o one:
Old Oct 11, 2015 | 09:29 PM
GMCtrk's Avatar
Is that still the 75/83 turbo? I'm running that same one on 15-17 psi. Time and raceweight in sig.
Also, I wouldn't worry one bit about popping the filter and tube off at the track. I do mine with no concern. And your filter looks relatively small so I'm sure you'd pick up some.
Old Oct 11, 2015 | 09:44 PM
69-chvl's Avatar
Yep same turbo, and you running basically the same mph with an extra 1500lbs confirms my suspicions that I should be running faster. Any other work done to the engine?
My airfilter is 7" long, it was the biggest I could get in there. I was thinking of installing a back pressure gauge to see if the engine was possibly working too hard for whatever reason to make the 16psi.
Old Oct 11, 2015 | 09:49 PM
GMCtrk's Avatar
just a stock 2002 6 liter with a triple 12 cam
Old Oct 11, 2015 | 10:19 PM
Forcefed86's Avatar
Your air filter is fine IMO. Mine isn't that big. Your times sound right for a 3600lb car using the basic HP calculators.
I was going 143 at 17lbs with an 8.6:1 5.3... same turbo. 2840lbs race weight. Which calculates to 665hp. At 3600lbs that would be 678hp.
http://www.wallaceracing.com/et-hp-mph.php
Old Oct 12, 2015 | 07:04 AM
RedRocketZ28's Avatar
Here's my car on 10-11 psi through the 3" exhaust out the back when it had the Turbonetics 7875 and TU1 cam. 1-2 shift happened at 5300 and I was leaving on no boost. This combo went a best of 9.92 @ 140 on 14 lbs. My Camaro is a 1SC stripper car but still weighed around 3450 with me in it.
For those that don't want to watch the video the results were:
60' - 1.77
1/8 - 7.06
MPH - 107.27
1/4 - 10.679
MPH - 136.84
With that being said, a 5.3, 93 octane, and 14*, I think you are doing alright. I was on E85 and 18* of timing.
Old Oct 12, 2015 | 09:08 AM
69-chvl's Avatar
Seems like the 6.0's run a lot stronger at lower boost, which I kinda noticed with LQ9 I had in here prior (RIP). Cant complain though for stock 5.3 (except cam) and cheap converter. I'd like to do a dyno tune before attempting to run it any harder.
