Oil everywhere under WOT
Turbo setups need a lot of venting. You're just pressurizing the block so much that its spewing oil out of every orifice. Rear main seal being the worst area.
If it continues after the reinstall above, don't get discouraged. You may need let the engine vent even more.
I ended up putting a catch can on the pcv side with this checkvalve
and I run a breather on the oil cap. When I want to spend more money I will swap that to another catch can for the breather but right now I dont really get any blowby and it works fine at 15 psi.
Pushing boost into the crank case is a good way to blow out an oil seal. Likewise, pulling much more than 3-5" Hg on the crankcase is a good way to suck one in. I run a sensitive gauge that measures 0-30" of WATER on my crankcase to determine the overall piston ring / pcv health when I boost any engine. A gauge like this,
http://www.ebay.com/itm/381017656706?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Should be reading something during WOT or else I start fixing my PCV plumbing until it does.
did you get the instructions? they definitely say do not hook the fresh air source to the TB unless you are n/a, and if boosted hook to fresh air inlet
please do not hook your can up some way other than the manufacturers instructions. not even if something else you may find on 'the internet'
the problem you are experiencing has everything to do with hooking it up wrong. you cannot run boost directly into the crankcase.
you do not need any bigger fittings, or any additional check valves please do not do this.
for more help please provide a photo of your current layout, and of course the email to the manufacturer is always the quickest way to get accurate info
more photos for reference:
Miljoco LP2507L240 Pressure Gauge 0 to 60H2O 2 1 2in 1 4in | eBay
But only a muppet would empty boost into theirs ! lol
This is how all factory turbocharged engines come, to achieve some form of OEM pcv activity during boost you must have a source of pressure drop. You adjust the signal via the adjusting restrictions between the crankcase, source, and air filter.
http://www.corvetteforum.com/forums/...post1590266523
This is we discuss how pressure changes based on velocity of flow,
http://www.corvetteforum.com/forums/...post1590423314
And here is where I use the same picture to great effect of explaining how PCV systems work on modern internal combustion engines
http://www.corvetteforum.com/forums/...post1590442241
This post contains an example of a factory PCV restriction fitting to increase crankcase vacuum signal
http://www.supraforums.com/forum/sho...1#post12069849
Any further quesitons leftover you may feel free to ask
How on earth do you expect a system at 10, 20, 30psi to pull vacuum from a crankcase ?
No restrictor or valve will ever allow that because the pressure difference is always in the wrong direction.
Your drawing will never pull anything from the crankcase under boost. It is physically impossible.
