Any Cam experts offer advice on a Cam for my setup?
I'm far from knowledgeable about cams and I'm taking some radical advice from someone I'm not 100% sure of their credibility. (Just haven't known him for long)
I wanted to pass it by some of you guys for opinions.
Car Specs:
Rearmount 78mm comp turbo, c5 z06. Basically stock ls6, tuned on a mystery "mild boost cam" which I'm not unhappy with, but I don't know any different. 2 separate build sheets show 2 different cam specs, but it's probably somewhere around 222/220 .596 .590 115 LSA
Sufficient fueling for what I want to do, which is 700-800whp.
Dual Springs, Head Studs, LS9 Head Gaskets, ls6 lifters.
(would like to go frontmount soon, but not happening yet). I run 12-15lbs boost depending on the moment. Haha. Dyno'd 650whp at 12lbs. Pretty dependant on 91oct + meth, but I plan on getting an additional E tune for the rare times I'm near an E pump.
The question:
I killed a lifter, and probably the cam. To replace the cam, I have 3 choices.
1) Throw in a stock ls6 cam (easiest option, as I already have a spare... but do you recommend better than ls6 cam?)
2) Throw in a more purpose specific cam recommended by you guys and/or a cam manufacturer
3) **Throw in the cam described below that is being endorsed by the guy I mentioned at the beginning, but it seems too inappropriate. This is the whole reason for my question.
the #3 cam: .625/.625 232/236 LSA112
N/A cam, but the guy is telling me that I'd be surprised how well N/A specific cam's work in a boosted application. And I wonder... then why are there cams made specifically for boost application.
That's a huge lift, but he says that an engine builder buddy back home says PTV would be fine. Is that way overboard for the 243 heads, wasting energy on such a huge lift? What about the rest of the specs? 112 would be pretty lopey I imagine. Of course I would love a kickass sounding idle, but how would that perform in my application?
I'm hoping to hear a common answer hear of either "that would be good", or "That would be stupid bad". Any other thoughts and advice is welcome.
Bonus Question
-Do you guys recommend ls7 lifters for a boosted application, or are ls6 just fine? I already have new ls6 lifters ready to go.
Thanks guys!
Random pic of my car for added Flavor
Car Specs:
The question:
Bonus Question
Thanks guys!
LS1Tech Sponsor
I would not use that cam for your application. An LS6 cam would work much better. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
I would go with the LS6 cam since you already have one. They've been used many times before in boosted applications with good results.
This is our stage 2 turbo cam for LS1/LS6 http://www.tickperformance.com/tick-...1-ls6-engines/
This is what i would use in your setup. As far as lifterts i would recommend Morel 5315 lifters http://www.tickperformance.com/morel...l-lsx-engines/
