Whipple build
Old Jan 19, 2016 | 02:30 PM
jimmyg's Avatar
Default Whipple build
Ok so I pulled the trigger on a whipple 2.9 for my lsx cutlass.
Right now car has a 2010 ly6 with a mast motorsports performance package.
Cam 224 238 .578 .593 115 lsa ( car has vvt)
Springs
Ecm/ harness.
Hooker 3 in ss exhaust
17/8 long tubes
How is this cam for forced induction? I realize it's not ideal, but I'm wondering how much power im gonna leave on the table using this cam. Also right now fuel system is corvette filter/ reg, racetronix 340lph, an 6 teflon lines. How can I upgrade this on a budget? Took me a while to save for whipple .plus I still have cowl induction hood to buy, and fig out front accesory drive. Thinking of meth injection since I will be running 93 e10. Straight meth or water/meth? . Talked to whipple and I guess easiest way is pre blower. This is my first attempt at FI so any help is apprec
Old Jan 21, 2016 | 08:35 AM
static low 92's Avatar
Jeez that is a clean cutty.
Love it.
Fuel upgrade would be dependent on HP goals I would think. A walbro single 460 is what I have with -8 feed/ -6 return. With a goal of 600whp, unfortunately Ive never got dyno sheet making serious power to see how it actually kept up.
Other common setups are multiple pumps with secondary engaged with Hobbs switch set to certain boost level.
Old Jan 23, 2016 | 11:11 PM
jimmyg's Avatar
Love it.
That's what I'm thinking dual in tank pumps with one on a Hobbs switch. Prob going to have to get rid of corvette/ reg and buy a regulator. Just unsure of what kind to get. Boost referenced? Or reg? Would like to see 600 rwhp on 93 with meth
Old Jan 25, 2016 | 03:51 PM
You will want to get a good quality boost referenced regulator.
Since your only running 93, that helps as well since Corn requires much more volume as well as buying fuel components that can handle it.
Old Jan 26, 2016 | 07:37 AM
jimmyg's Avatar
What do u think? -8 from tank to rails -6 return? Or can I keep it all-6?
I spent a lotta $ on current fuel system so I would like to use as much as I can
Old Feb 4, 2016 | 02:24 PM
I don't think -6 is sufficient for feed.
You'll need -8 imo
Old Feb 4, 2016 | 05:13 PM
jimmyg's Avatar
Old Feb 4, 2016 | 05:27 PM
speedtigger's Avatar
Old School Heavy
I am jelly. I have a soft spot for the Whipples. Your cam will be great for what you are doing. If it were mine, I would degree it to a 113 Intake centerline and rock it.
Old Feb 4, 2016 | 07:41 PM
jimmyg's Avatar
That's great to hear, I was worried about the cam. I bought the hotrod kit so I still have to pick a heat exchanger, injectors, upgrade fuel system ect... Mast is sending me a tune .
Old Feb 6, 2016 | 08:47 AM
Jimbo1367's Avatar
I love the Cutlas. What was the ballpark $ for the whipple? Subscribing!!!
Old Feb 6, 2016 | 10:57 AM
jimmyg's Avatar
I bought the ls3 hot rod kit ,$5920 shipped.still need about 1k to install.lol still needs a heat exchanger, pump, injectors, then I have to move Ac , alt. upgrade fuel system etc..
Old Feb 6, 2016 | 07:19 PM
jimmyg's Avatar
Question, should I pull the heads and go ls9 gaskets and head studs? Just put new Mls gaskets and gm bolts 4k ago when I put car together. Plan on 10 lbs boost.
Old Feb 7, 2016 | 08:01 AM
Jimbo1367's Avatar
thanks for the info.
I would ditch the stock solid intake valves.
Old Apr 27, 2016 | 09:01 PM
jimmyg's Avatar
Do you think the valves will make that much of a difference?
Old Apr 28, 2016 | 10:21 AM
Old School Heavy
With a good dual valve spring, I would not worry about the valves. They will be fine.
Old Apr 28, 2016 | 07:25 PM
jimmyg's Avatar
Haven't updated this in a while, but I'm still collecting parts. I want to get most of them before I tear it apart. Should be able to start in 3 weeks or so
Old Apr 28, 2016 | 07:26 PM
jimmyg's Avatar
This is what I've got so far
Old Apr 28, 2016 | 09:17 PM
Razor's Avatar
What are you gonna use for reservoir tank?
I previously had a Whipple on my car. Used a 5 gallon tank mounted in trunk that I could fill with ice. Worked decent for track work. Volume and flow are your friend. Pump doesn't need to run all the time either. Use a hobbs on it with an override switch.
Loved the low-mid range fun with the help whipple. Wish I would have added a direct port kit on it and left it alone.
Old Apr 29, 2016 | 03:08 AM
ajrothm's Avatar
The cam will be fine... I ran almost the same cam (226/238, 115lsa) and made 901 rwhp with it in a 402"... It should work great with your whipple.
I would sweat anything in your motor... Slap the blower on and go.
Old Apr 29, 2016 | 05:01 AM
jimmyg's Avatar
I'm kind of up in the air about the reservoir . Whipple suggested a 2 gal canton tank that fits in the battery location . I love your camaro by the way, did you end up selling it? Your build kind of pushed me in the direction I'm going. Lol
