Wastegate size suggestions, Please Help
Old Feb 24, 2016 | 12:06 PM
salemech's Avatar
Default Wastegate size suggestions, Please Help
I currently building an 346 76mm Single turbo, any advice on the waste gate size. i have absolutely no idea how to choose the right one.
Old Feb 24, 2016 | 07:26 PM
95silvia14's Avatar
Tial 44mm
Old Feb 24, 2016 | 07:47 PM
salemech's Avatar
Originally Posted by 95silvia14
Tial 44mm
How do yo usually calculate it. this is my first time building a turbo engine.
thanks though
Old Feb 24, 2016 | 10:21 PM
RealQuick's Avatar
How much boost you plan on running?
Old Feb 24, 2016 | 10:24 PM
a4ls2goat's Avatar
the more boost you run the less wastegate you need.
denmah's Avatar
Moderator
cubes + turbine size + minimum boost \ placement = wastegate size
but yes, simple single turbo fbody style build single 44 and ship it
Old Feb 24, 2016 | 10:31 PM
salemech's Avatar
no more than 17psi
Old Feb 24, 2016 | 10:34 PM
salemech's Avatar
what do you mean placement.
so what i understood is
346+76mm+10psi \ placement
is that right?
Old Feb 26, 2016 | 04:11 AM
SPRAYED 01's Avatar
If you want to try and regulate it very low then the bigger the better. I run a tial 38mm with 20psi, 370 CI 900 whp.
But short answer is just get a 44mm and call it a day. Wont really matter all that much if its a run of the mill setup and you dont plan to be below 6psi.
Old Feb 26, 2016 | 04:46 AM
gtfoxy's Avatar
For me, big enough so that it doesn't creep. I hate that.
Old Feb 26, 2016 | 09:15 AM
SwampWS6's Avatar
is that right?
Ditto
