Where is a good place to buy a tank for methanol?
I recently purchased the cooling must kit and need to get a tank. I'm unable to use the stock windshield washer tank due to space constraints under the hood.
I thought I had saved a link that was posted up but can't find it and search is too vague.
I did find this place last night and it appears to be the same tanks without names on them.
http://www.usplastic.com/catalog/item.aspx?itemid=23334
Anyone else have any links?
Do u know about what size your looking for I have seen several online just plain Jane one gallon to five gallon tanks I know devils own sells just the low fluid level sensor so u can put it into any tank u want also some tanks have a mounting place for the pump with a built in low fluid sensor and filter I see lots on eBay and devils own website also alky control which is who I used sells a killer jaz one gallon fuel cell with built in sensor led switch and mounting tabs it's like 160 I think but it's definitely top notch looking for sure
Poly mower fuel tanks work well if you want cheap.
http://www.ebay.com/itm/OEM-RIDING-L...UAAOSwKtVW0IcR
You can get the AEM tanks with low level sensor already tapped from Jegs for $84
http://www.jegs.com/i/AEM/017/30-332...FQyHaQodtLUF4Q
Alcohol Injection Systems make the best tanks.
Although Devil's own do some nice ones too.
Just depends whether you're after something cheap and nasty or something nice and neat.
I got the tank and cap yesterday and it seems very solid and I would recommend it so far by appearance only. We shall see how it holds up.
Not sure how to post a link to the eBay image links but if you could share the info that would be great.
Float sensor.
https://www.ebay.com/ulk/itm/171813931722
Various tanks. If you view the full site you can pull up pdf's with drawings.
www.usplastic.com/mobile/item.aspx?itemid=23334
Float sensor.
