The great fuel line debate.
After the first dyno session, I knew there was a restriction issue (see pic)
Did make 651 whp thru this and 1/4" line increasing to a 6an line midway up the car.
I was thinking of going to a -8 feed with a -6 return and possibly even adding a 2nd walbro 400 if I can squeeze it in there. What I am having a hard time understanding is what benefit is putting a large fuel feed line on a pump that only has an outlet of less than 3/8"? I believe the id of the walbro 400 outlet measures less than 1/4"
Can someone help me wrap my little brain around this so I can decide what direction to go?
Set up is a 5.3, good rods and pistons, pt88, ljms st2 cam, 243 heads, ls6 instake, deka 80's and currently a single walbro 400 in the stock tank.
Thanks
10 ft of 1/4" hose has a greater restriction than say 1" of 1/4 hose transitioning to 10ft of 3/4" hose.
What type of fuel?
How much power do you want?
It generally costs very little to bump up the next size hose when planning a fuel system. I usually figure out what I need roughly, then bump up to the next size.
Pro Mod guys use -10 line to their rails and make ~4000 HP on methanol. Fuel pressure helps.
Now -6 with any bends is too small and -8 is way too big?!
Crf450 -Dave is a amazing engine builder- good job!
I've gotta 5' rise from my tank to fuel rails....running a AEM 380 that's got a -10 inlet and a -6 out so I guess I need to use the -6 up to the rails......using the factory rail supply line....
Standard Russell, Redhorse, and many other -6an bends are connected with what would be about -5an if they had that as a size. They restrict the size down to about .272" and if you run the same through that size straight it will have more friction than the size it claims to be. Pretty simple.
If you have a straight -8an it is .500", but those fittings are the same from the standard makers. The bends would be a -7 if they made them.
You also need to keep in mind bends of any size are a restriction.
If your run -6an with fittings from here: http://www.australianracingproducts....ings-and-hoses
You can flow up to 480 gallons or 2150 liters per hour through 8 foot of hose up 6 feet and the pump will be pumping about 5 psi more than you have at the rail. You can make a lot of power from that. If you don't believe the numbers just look at the size of the outlet of the intank pumps. My car has a 450LPH pump with about a 1/4 inside diameter outlet. It's has a cross in it so it's not even and open 1/4". People do way to much line.
-8an is good to 850 gallons per hour.
All though it is recommended to stay between 1 and 4 feet per second. It is way more important to stay below 4 as having it to slow is still enough fuel to not burn up the motor. I think you would have to run 1 inch line to have it so much over done you would have engine trouble. So, run larger if you like and keep in mind -6 is not really .375" unless you source the right fittings. Just don't run to small.
