Need help from the high CR boosted guys
Boosted engines make the most power possible with low static CR and high boost, this is true. But it's only really pertinent for a pure race car. For a street driven car, I believe you're better off with slightly less peak power, but more usable power from the much wider torque band you'll get with a higher static CR and lower boost.
my last motor was around 11.5:1 25psi boost 408ci pump e85.
rebuilt it now and have dropped to around 10.0:1 comp. why? because yea e85 will take the compression and boost, but it makes the tuning window very small. 1 tiny fuckup and shes all over.
