Anyone running twin on3 61mm turbos
Just wondering if anyone is using the on3 61mm turbos for twin set up. Also would you recommend them. I'm looking at them cause there only $320 a piece.
I got a pair of On3 61s, but the car hasn't been tested yet. Only 4-5 miles on car, still at the upholstery shop.
6.0 with a small cam(223/231) and .68 a/r housings,turbos light right up. Might be too fast into boost,6-7lbs @ 25-2600rpm. that's with a tight converter 23-2400 stall in 80E.
These 61s would be great for a manual trans or 5.3L
You could make 600hp on twin 50 trims. It will be more than enough.
Here is a full work up with my car. Twin 67's, 5.7, 6 speed. All info
https://ls1tech.com/forums/forced-in...7-turbo-s.html
side question-
anybody run these gt35 clones yet? are they billet? the v-band in/out turbine housings look nice, especially if the comp wheel is billet. ball bearing worth it?
http://www.on3performance.com/shop/o...-turbocharger/
If you're on a tight budget, cx racing http://www.cxracing.com/mm5/merchant...gory_Code=INCO
If you want a quality intercooler, treadstone http://www.treadstoneperformance.com...cooler++1000HP
Both of those cores are the short version, both are made in a taller version
http://www.treadstoneperformance.com...bo+Intercooler
I think you'll be happy with them. On3 has their smaller twin 55s on 5.3 pickup it made over 600hp & 675tq at 13 lbs with E85 thru a 80E. And working on their 4th gen Camaro kit with twin 61s
