Procharged 396 LTX (built by ellwein)
Old Jul 12, 2016 | 01:18 PM
  #41
97SSD1's Avatar
Originally Posted by Bob@BruteSpeed
Looking really good! Bob
Thanks Bob! Probably gonna be in the market for an F series Procharger once this thing gets up and running.
Old Jul 16, 2016 | 07:22 PM
  #42
97SSD1's Avatar
Default Brake Setup
12.8" C5 Corvette rotors w/ new painted C5 Calipers w/ Hawks HPS pads.
C5 Brakes
Old Aug 3, 2016 | 08:20 PM
  #43
97SSD1's Avatar
Default Clutch
Mcleod Twin Disc installed with ARP pro series flywheel bolts.
Old Aug 3, 2016 | 09:53 PM
  #44
Blackbirdws6's Avatar
How close are you to dropping it in?
Old Aug 4, 2016 | 04:27 AM
  #45
97SSD1's Avatar
Hopefully next day or two dropping it on k member. Then mating body and subframe over the weekend.
Had a plan for my fuel setup, and decided to just do the Lonnies route plug and play to make life easy.
So still waiting on its arrival...
Just gotta make up some more -8AN fuel line since I already was setup with AN fittings on fuel rails with stand alone Aeromotive FPR.
Old Aug 4, 2016 | 10:57 AM
  #46
Bob@BruteSpeed's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
Sounds good! Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old Aug 4, 2016 | 11:18 AM
  #47
hokeplaya05's Avatar
what flywheel is that? how was the installation process of the clutch? I have a street twin and light weight flywheel form McLeod sitting on a shelf in my garage waiting to go on my car
Old Aug 4, 2016 | 03:56 PM
  #48
97SSD1's Avatar
It is a steel flywheel from mcleod. Comes as a kit: Flywheel, bottom disc, floater, top disc, pressure plate, throw out bearing, master cylinder.
The steel flywheel is supposed to be easier to drive on the street, but doesn't rev as quick...I stuck with steel Cuz this is my street car.
As far as installation, it was very easy outside the car. Kinda disappointed I spent $1500 on a clutch and they didn't include flywheel bolts or throw out bearing....
Just follow the directions, keep everything lined up, and for the love of God don't mess with any of the shims or it has to go back to mcleod.
Old Aug 5, 2016 | 11:21 AM
  #49
okay cool, thanks. I have their aluminum flywheel and I will be installing everything with the motor in the car so that should be interesting. pretty sure mine has a throw out bearing but will have to check. I have heard that about the shims so I definitely wont be touching those lol hoping to install everything next week if I have time and some good weather as I will be doing it in my driveway
also, what did you do to fill the EGR ports? always see the block off plates, never seen them filled like that
Old Aug 6, 2016 | 12:48 PM
  #50
97SSD1's Avatar
Good luck on doing it in your driveway. It would really help the higher you get the car off the ground. If you were to do it on a lift it would only take about 15min to get everything torn down to the clutch, buuttt...in your driveway I dunno.
The EGR stuff is just welded shut, then powdercoated. Same with the PCV port on the side of the intake since I have custom breathers coming from the valve covers to the catch cans.
Old Aug 8, 2016 | 11:40 AM
  #51
lol thanks, yea I will be getting the car up as high as I can for sure so I have plenty of room underneath.
anyways cant wait to hear this thing run, especially with a procharger hanging off the front of it!
Old Aug 18, 2016 | 04:42 PM
  #52
97SSD1's Avatar
Default Progress
Slow progress is better than no progress.....This Florida heat in July and August is killin me. I finally broke down and got an A/C unit for my garage. It has been 95+degrees outside, but now with the A/C in the garage its a cool crisp 80 degrees lol (Very Low Humidity though!).
Anyways just an update, will include pictures later....Engine is on K member, Trans is on, wiring harness all hooked up, all accessories on, headers on, AN steam pipe setup done, about ready to drop the Body back on the k-member. I wish I had the room in my garage to do this without opening the garage door and could just run the A/C, however I don't. So I'm gonna sweat it out this weekend.
Once the two halves mate I still gotta install the new BeCool Radiator, new stainless braided fuel lines/filter, then the Alky Control Meth system. After that she will be ready to roll. Already have a baseline tune (based off my cars previous tune) that should get me up and running. Then need to get towed to the alignment shop and have the front end sorted out, then drive the car for around 500miles(daytrip down to Daytona and back) then DYNO DAY!
Very, Very tempted to buy an F1-A blower before dyno day...I even have the correct pullies already to max it out...Anyone wanna buy a D1SC w/ about 600miles on it (Oil changed 3 times already)?
Anyways, I'll keep posting progress....Also if anyone could give me some know how to upload a video, that would be awesome. I have one of my engine on the "engine dyno" and would like to be able to load one up on the chassis dyno as well.
Old Aug 18, 2016 | 04:46 PM
  #53
LS1Tech Sponsor
I can have an F-1A headed your way pretty quickly. Bob
__________________
Old Aug 18, 2016 | 04:54 PM
  #54
97SSD1's Avatar
Default Blower!!!!
I know you can....If I wasn't in the middle of having to move NEXT MONTH I would be on this like white on rice. I think I just need to run what I have, get established and pick up the new blower in a few months, because I really want to keep my D1 blower and put it on my truck. Right now only way I could pick up an F1A is if someone paid me good money for the D1SC I have now. Ohhh first world problems.....
p.s. Plus I would feel kinda silly since I just bout that 8.5" crank pulley, then drilled three holes in for the ATI damper so I can't return it now....do they have a 12rib setup for a 98 chevy vortec 5.7? or is it only serpentine systems?
Old Aug 31, 2016 | 09:52 PM
  #55
97SSD1's Avatar
She's in there!
Old Aug 31, 2016 | 09:55 PM
  #56
97SSD1's Avatar
I need to get ahold of Walter Whites hahaha
Old Aug 31, 2016 | 10:00 PM
  #57
97SSD1's Avatar
Default Big *** swaybar
Big *** swaybar
Old Aug 31, 2016 | 10:45 PM
  #58
DavidBoren's Avatar
This is refreshing. Lots of very cool detail in this build. I think the D1SC will do very well getting this thing up and running and all the kinks worked out. Very interested in your results.
Old Aug 31, 2016 | 11:03 PM
  #59
MY_2K_Z's Avatar
She's in there!
Holy chit that's a big crank pulley!
Old Sep 1, 2016 | 05:07 PM
  #60
97SSD1's Avatar
Yeah...8.5" with a 3.7" blower....will max out the D1 at 6500RPMs. Gonna be going to the F1A down the road, and swap back to the 7.65" and prolly max it out too
