Max effort SBE cam selection
Ive been contemplating camming the car and was looking at the ljms stg2 but was informed that it may cause backpressure issues with the small turbine. Whats everyones suggestion for a max effort Ls1 sbe cam? Would like to see if i can push the engine above 700whp. If it lets go, it lets go, but would like to make a more legitimate attempt at going over 700 besides just turning the controller to the right, adding fuel, and adding timing.
A "Max effort" cam for a high back pressure setup will be a low duration cam with little overlap. You'd be much better off ditching that dinky turbo in favor of a "big" single, or buying another just like it and running twins.
Anyone with any experience with the tc78 wanna chime in? Where did it quit?
i just picked up an lq4 block and crank a few weeks ago , its at the machine shop. Looking to run up past 1000hp on the next build with a t6 and rect. Port heads.
Though for a little more $ you could bolt on a VSracing 88/83 or 76/83mm turbo or a t6 S475...
And simply 'adding timing' on a stock bottom end is usually what does them in, not power/torque. If you really want to see how far you can stretch it, keep the timing low.
You will absolutely gain power with a cam swap, but its probably not going to make that drastic of a change once you max that turbo out.
