Maybe FiTech learned LS engines matter? :)
#83
So you are using this on a BB, I guess the same thing of longer wires would hold true on an LS engine, I guess better than to short.
An unterminated kit with all the ends would be cool.
I am at the point of needing a controller, and trans controller, so the $999 Fitech looked interesting, but having used a couple Holley HP's, I know what they can do, but, $$$$$$$$$$$$$$$$$$$$$$$$$$$$$, lol
#85
That's MISTER MODERATOR
Hey Andrew, perhaps we're talking about different HP systems. I looked at the HP EFI ECU & Harness Kit for GM LS1/LS6 # 550-602.
It allows the option of a second o2 and add on touch screen.
https://www.summitracing.com/parts/hly-550-602
Which HP system are you referring to that's $1,800.00 that includes the touch screen?
#86
The 550-602 only has one 02 sensor, you have to go to the Dom. to get a second-the Dom allows. trans control also, of course more dollars too.
I used the small 3" touch screen with my HP, it eliminates having a cab full of gauges, you can program the screen to view what you want, and add cautions (turns red) if something is out of your programmed range-you can snag the screen for $225-250 on a deal. I actually was able to get the screen and the HP for a little over $1700 on a deep deal, but haven't seen any bargains recently.
#87
PN 550-608...It's one of the Terminator kits. I hate the Holley nomenclature because it is confusing. But as was said above, the HP can only do one O2.
Andrew
#89
Presumably at only $1000, the FiTech is using a pair of narrowband sensors ? I cant imagine the system including 2 widebands at that price...and narrowbands do have limited use in the performance world.
So on many levels any comparisons are a bit pointless. But $1k for a complete system no matter what way you look at it, has to be good value as long as it is actually functional and reliable.
#91
OK folks, I can offer an update.
There are some things about the harness that’s a mystery. FiTech does not include a schematic in the installation instructions and refuse to provide one when asked. “We don’t share our pin-outs, it’s a proprietary ECM”. Others include it with their instructions-and their controllers are proprietary also. Almost all my questions to them would’ve been answered with a schematic.
Most of the wiring follows or almost follows standard GM color codes and it’s easy to shorten the wires one at a time. But, the fuel injector harnesses, which unplug from the main harness, are not standard GM color codes and are not marked which plug goes to which injector. The main harness injector plugs are marked “P” or “D” for sides but I suppose we should assume the injector plug closest to the main plug is the rear injectors and work forward. When asked for confirmation, FiTech again reiterated they don’t give harness “pin-outs” as they call it.
The instructions clearly describe fuel pump pulse width modulation to control the fuel pump speed. It even states how to change the setting in the touch pad. The fuel pump is fed through a relay. This is a standard contact style relay, not a solid state relay that would be needed for PWM voltage control.
I was first told that it was PWM and that I was wrong. Then I was told to speak to Bryce, as he’s the “Ultimate LS system guy”. He couldn’t answer either. Although he told me he answered all the questions in my email (there were four, he answered one), I pressed him for the fuel relay answer and he finally said it was an early instruction and regular on-off contact relays is what the kit comes with.
When I speak with FiTech support, answers are very short and with an “everybody knows that” attitude. I have the feeling that they think if a user can’t figure it out for themselves from the instructions, he’s an idiot.
Other than all this, I do feel the harness and it’s implementation is decent to good. I’m sure once I have it all up and running, it’ll be nice. The software looks to address just about everything. Here’s a screen shot of some of the features.
#92
Thanks for the screen shot, some of the stuff looks confusing as far as what does it mean, lol-like the trans stuff
Funny the Holley HP has a full wiring diagram, esp since you have to do "pins" when adding stuff, plus I had an early HP that they used a diff vendor making the harness, and it had some swapped wiring-but thanks to the wiring diagram I was able to correct.
#93
I was actually linked to this thread from a post in a thread I started over at Chevelles.
I received the 70051 stand alone system yesterday. It's very nice, complete and nothing damaged. It was in stock at Summit.
I don't think anybody in this thread mentioned it, this is a speed density system, no MAF.
The injector harnesses are for LS1 injectors. If you're using EV6 injectors, you'll need adapters or need to change the plugs.
The harness sections are too long, I'm sure most users will shorten everything up.
My twist is I'm installing this on my 496 big block, which has been outfitted with LS1 sensors.
I have a bunch of other things to do so it'll be a while before I actually fire this system up.
I'm working my way through the rest of the replies and will let you know if I find anything else.
#95
If the system works as it should $800 is a bargain even just for he engine side. I priced out a boost capable HP system and it was over 2k and the PCM was maxed out for drivers. I would have to step up to the dominator ECM for 2k by itself.
#96
Yea I got different answers from Kirk and the other guys at FItech, honestly they are not the best tech savvy or customer service. I don't mind that if the product is good and easy enough to use. Has to be easier than the stock stuff and HP tuners.
I did confirm dual subharnesses as I purchased EV1 to EV6 adapters after they told Me they only came with EV1. Now after getting the kit I could have saved the $25.
I did notice that my LS1 99 stock 5.3 harness uses a 1 wire alt plug and the FItech has a 2 wire plug.
Get her all done and fired up and report back. Another guy has his started and idling but his coils took a dump so it's idling rough in another thread here.
#97
#98
I think the 500HP system comes with one, the 700HP system two. The basic system I bought (without intake, injectors, rails, etc.) doesn't have a HP rating and it came with two o2 sensors.
The software is in the touch pad. You remove it from the system and connect via a mini USB plug and it powers up. It appears you work on it offline then re-connect and dump into the ECM.
Where's that thread?
Here's the thread. I have also figured out a harness adapter to run a LS1 style MAP sensor with the LS3 connector provided on the FItech harness. Took me a while to find it as they all convert the LS3 sensor to a LS1 harness and not the other way around. https://ls1tech.com/forums/forced-in...l#post19717965
