L92 and boost
Old Oct 26, 2016 | 12:34 PM
ricardo.benin's Avatar
Default L92 and boost
Hi I am building an l92 for boost and was wondering can I push 700whp l92 heads? I plan on getting scat rods weisco Pistons and run a stock crank with main studs. What Pistons should I get for boost?
Old Oct 26, 2016 | 12:39 PM
svslow's Avatar
Is the L92 still together? If so, leave it together and add boost.
Old Oct 26, 2016 | 12:52 PM
It is torn apart because of a bad lifter, I am getting lifter bores machined and bushes as I had some damage
Old Oct 26, 2016 | 12:53 PM
I heard the l92 heads have a thin deck and will start to float?
Old Oct 26, 2016 | 12:54 PM
JoeNova's Avatar
Restricted User
Let me redirect you to this EXACT same post you made last month.
https://ls1tech.com/forums/forced-in...l92-boost.html
Old Oct 26, 2016 | 03:07 PM
Yeah but I have been reading that the factory heads have a thin deck that floats
Old Oct 26, 2016 | 04:18 PM
JoeNova's Avatar
Restricted User
Stop reading so much.
Old Oct 26, 2016 | 04:20 PM
oscs's Avatar
I've taken my L92 heads and factory LS3 intake to 28lbs on MANY occasions. They are no different than a 799/243/806/823 castings. The only "thick deck" factory heads are the LSA.
Square your tune up and let it eat. 700whp is a joke for a good running L92 motor.
oscs's Avatar
This.
Old Oct 27, 2016 | 12:50 AM
Appreciate it, I tend to be a book worm.
Old Oct 27, 2016 | 08:08 AM
oscs's Avatar
It's better than the opposite that's for sure.
Old Oct 30, 2016 | 03:11 PM
So just an update, the Pistons have some ware on then so I can going to replace them primarily as I found a good set of Mahle Pistons, L92314070F05 there specs are L92/LS3 Chevy PowerPak Piston & Ring Kit
  • Forged 4032 High Silicon Aluminum Alloy
  • Bore: 4.070"
  • Pin Diameter: 0.927"
  • -4cc Dome Volume
  • Compression Ratio @70cc: 10.1:1
Will these Pistons help in making the power I want as compression is lower, I don't know a whole lot about compression numbers.
Thanks
Old Oct 30, 2016 | 06:37 PM
oscs's Avatar
  • Bore: 4.070"
  • -4cc Dome Volume
Thanks
10.1 is the most compression I would use on a FI motor. Those Pistons will work.
Old Oct 30, 2016 | 08:03 PM
Could I further lower compression with a thicker head gasket?
Old Oct 30, 2016 | 10:58 PM
brandon6.0's Avatar
Yes. Run ls9 gaskets and head studs. Might as well install bigger valve springs while heads are off.
Old Oct 31, 2016 | 10:55 AM
Ok , will do
Old Oct 31, 2016 | 10:56 AM
Ok thanks
