ls3 block
Old Dec 29, 2016 | 05:04 AM
sbf's Avatar
sbf
Default ls3 block
hi guys would a ls3 block hold up with a s485 making around 900-1000 rwhp.building a street/strip car pump gas
Old Dec 29, 2016 | 06:55 AM
408GT's Avatar
Yes..
Old Dec 29, 2016 | 12:10 PM
Nathaninwa's Avatar
Another vote for yes
Old Dec 29, 2016 | 03:20 PM
408GT's Avatar
on a 75mm turbo
Old Dec 29, 2016 | 04:03 PM
sbf's Avatar
sbf
Originally Posted by 408GT
yes i seen that just wanted to make sure,and how it would hold up with street miles and track passes
Old Dec 30, 2016 | 08:59 AM
Bob@BruteSpeed's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
With a good tune and good fuel you should not expect to have any problems. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old Dec 30, 2016 | 11:48 AM
pantera_efi's Avatar
Default LS-3 Block Strength
NO, to be fair AND as listed by GMPP.
There are FOUR items that will make this work.
1. Install LS-7 "billet" main caps.
2. Use/install a 58x crankshaft target wheel.
3. Use Chinese head studs.
4. ARP Main Studs.
Lance
Old Jan 8, 2017 | 02:04 PM
sbf2's Avatar
4. ARP Main Studs.
Lance
i understand having the arp main studs and head studs but why ls7 billet cap and 58x target wheel
Old Jan 8, 2017 | 02:12 PM
Nathaninwa's Avatar
I didn't know about the maincaps and the ls7 having steel billet. But under power the cap try's to fold in half which kinda causes it to twist in the bore taking out bearings. Not sure there needed at the 900/1000 range but the safety would be there
The 60 tooth wheel provides better timing accuracy creating a more stable tuneup
Old Jan 8, 2017 | 02:19 PM
sbf2's Avatar
Originally Posted by Nathaninwa
I didn't know about the maincaps. But under power the cap try's to fold in half which kinda causes it to twist in the bore taking out bearings. Not sure there needed at the 900/1000 range but the safety would be there
will i be able to run the 411 ecm with the 58x and would it be a good idea to half fill the block
Old Jan 8, 2017 | 02:26 PM
Nathaninwa's Avatar
I run all standalone stuff. The block fill is 50/50 on the internet weather it's needed or not. Mine is not. But by design the LS block is rigid being a Y design, and mine is motor plates front and rear providing more stability and getting the force off the side of the block
Old Jan 8, 2017 | 05:31 PM
oscs's Avatar
58X reluctor wheel crank is far from a "necessity" the Billets caps are a decent idea to try and give the block a little more rigidity but know that 1000whp is asking a lot from a factory GM aluminum block. Your flirting with that line at that level. I've seen my fair share of LS2/3 blocks thrive at 900whp and start spitting bearings out at the 1000whp mark.
Old Jan 8, 2017 | 05:33 PM
oscs's Avatar
This. A motor plates go A LONG way on an LS3 block. IMO half fill is damn good idea for an LS3 block if there are no plans to run motor plates.
Old Jan 9, 2017 | 01:59 PM
Default Powdered Main Caps
Hi SBF2, the GMPP rating in HP is given, largely, by Main Cap material.
The LSA SC block's main material was steel.
The "truck" block was Billet Steel.
Thus the possibility to "find" a broken LS-7 block, low cost if not free, would allow a main cap interchange.
MY witness of a LS-2 "powdered main" was a cracked #5 @ 1000 RWHP.
The use of a 58X TW would be of great help allowing much better Spark Accuracy, GOOD for engine life.
Lance
Old Jan 9, 2017 | 02:05 PM
sbf2's Avatar
ok thanks
