Help with a build
Old Mar 22, 2017 | 03:50 PM
phdatsun's Avatar
Default Help with a build
Hello Everyone I just joined this forum hoping to find some help on my build. I am building a Twin turbo lsx engine that will be going in a old jet boat. Im shooting for about 1500hp tops when I need it and 800-900 when putting around the river. I have a AEM infinity ecu and ID1700 injectors. This will run on pump and race gas no e85. I also will be using some Garrett GTX3582r gen 2 turbos. There a bit on the small side but i want my power come on fast. I need help with the bottom end. What do I need to reliably hold this. I will be using Carrillo rods and CP pistons but not sure about the crankshaft and block. Im thinking LSX block and a callies dragon slayer, magnum or billet crank. Also not sure what my bore and stroke should be. Im thinking 4.125 bore and 3.8 stroke. Also not sure if I should run a tall deck and get longer rods. Any input would be greatly appreciated.
Old Mar 22, 2017 | 06:55 PM
SethU's Avatar
What make is the boat and jet and have you had jet boats before?
Old Mar 22, 2017 | 06:57 PM
phdatsun's Avatar
It is a 1986 Wilder craft. I owned a POS witchcraft that did about 55 mph with a 455.
Old Mar 22, 2017 | 07:16 PM
SethU's Avatar
What jet pump is in it? Know any of the specs?
Old Mar 22, 2017 | 07:29 PM
phdatsun's Avatar
The boat and pump are at gs marine getting an inducer and stainless impeller plus the works. Not sure what impeller. The pump itself is a old dominator. Im having them set it up for 1000hp around 6200. I plan to max out around 7500 rpm leaving some extra room. I don't know if I'll ever turn it up that high depends on how it feels.
Old Mar 22, 2017 | 07:40 PM
SethU's Avatar
Question
That's a good boat and drive. What engine parts do you already have?
Old Mar 22, 2017 | 07:53 PM
phdatsun's Avatar
I'm pretty much starting from scratch. I just did a full 180 on my original plan. I have a rock crawler with a 6.0 with prc 2.5 heads eagle rods and 11:1 mahale pistons and cam. I pulled the motor was going to put a couple turbos on it and a bigger fuel system and try to make 1000hp but then I got paranoid of it grenading at big mph and decided to do it rite. So now I have a fuel system and a couple turbos. I own a utv performance shop and am a cp/Carrillo distributor and know those are tough parts so they will make me what ever rods and pistons I come up with. I need a block and crank first but not sure what bore and stroke to make it. Also not sure if I need a billet crank.
Old Mar 23, 2017 | 09:27 AM
SethU's Avatar
Seems, by your choice of turbo, that you're not afraid to drop some coin on the project. Personally, I'd stick with the standard 6.0l bore and stroke dimensions. If I had the cash to spare, I'd be shopping for an aftermarket aluminum block, RHS perhaps. If not that much money, LSX or similar.
For my boat project (v-drive) I decided to go the route of disposable engines and am only shooting for 800 FWHP.
Have you ever been in a fast boat that's the same size?
I'm in Lodi, CA. Where do you live?
Old Mar 23, 2017 | 11:01 AM
phdatsun's Avatar
I am getting a aftermarket block. Probably the lsx block but not 100%. Id love to have a aluminum one but there double the price. Fastest boat I have ever been in was a 700hp gullwing. Got me hooked. My goal is to be able to adjust my power on the dash from 700-1500hp. Not sure if I will ever have the ***** to turn it all the way up but you never know. Im in san diego.
Old Mar 23, 2017 | 07:25 PM
SethU's Avatar
Any idea what speeds?
Old Mar 23, 2017 | 07:55 PM
phdatsun's Avatar
It did low 90s.
Old Mar 23, 2017 | 10:27 PM
SethU's Avatar
GPS or seat of the pants?
