98 Camaro 408 S488 Huron speed v3 t6 hotside kit.
Old 03-26-2017, 08:59 PM
xXLindquistXx's Avatar
Default 98 Camaro 408 S488 Huron speed v3 t6 hotside kit.
I recently received the new Huron speed V3 T6 hotside and got it installed this weekend. Everything fit great and the quality is awesome. I highly recommend Huron speed for all your turbo needs. great company and great customer service. I cant wait to get it on the dyno and see what it can do.
Attached Thumbnails 98 Camaro 408 S488 Huron speed v3 t6 hotside kit.-dsc_0064.jpg   98 Camaro 408 S488 Huron speed v3 t6 hotside kit.-dsc_0065.jpg   98 Camaro 408 S488 Huron speed v3 t6 hotside kit.-dsc_0067.jpg   98 Camaro 408 S488 Huron speed v3 t6 hotside kit.-dsc_0068.jpg   98 Camaro 408 S488 Huron speed v3 t6 hotside kit.-dsc_0069.jpg
98 Camaro 408 S488 Huron speed v3 t6 hotside kit.-dsc_0011.jpg   98 Camaro 408 S488 Huron speed v3 t6 hotside kit.-img_2287.jpg
Old 03-26-2017, 09:56 PM
kdavis's Avatar
Can't wait to see some numbers.
Old 03-29-2017, 10:05 AM
LS1Tech Sponsor
Superman09's Avatar
Thanks for the good words, glad you are loving your new V3 T6 Hot-side!!
Looking forward to seeing your results as well!
Jon
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Old 03-29-2017, 07:44 PM
fastcars95's Avatar
Very nice setup
Old 03-29-2017, 08:19 PM
2000GTP's Avatar
Looks great, can't wait to see final results.
Old 05-31-2017, 02:15 PM
Rise of the Phoenix's Avatar
OP, did you ever get the car on the dyno or to the track?
Old 06-04-2017, 05:53 PM
sorry for the late response yes i had it on the dyno couple weeks ago. it made 792 whp on 13 psi. My torque converter is very loose and it was blowing through so we didnt get to turn the boost up any higher. I also had it at the track this weekend and it ran a 10.15 at 145mph. with a terrible 1.9 60 foot .
Old 06-05-2017, 10:42 AM
The BallSS's Avatar
10.15 at 145 lmao.
Old 07-17-2017, 07:31 PM
QuickdomesticRacer's Avatar
The bracket that attaches to the oil return on the turbo. Where does it bolt up too?
Old 07-17-2017, 07:47 PM
its suppose to bolt to the factory alternator bracket but mine is relocated and i made a spacer out of sqaure tubing to take the place of the bracket
Old 07-17-2017, 10:51 PM
V-10 Killer's Avatar
No flex coupling on the passengers side charge pipe? How did that fit? Just curious because my v2 kit had one, and even then it took a bit of persuading.
Old 07-21-2017, 05:37 PM
it was hard and time consuming to get it on. never really did get it perfectly lined up has a leak at one of the vband but huron speed is taking care of the problem.
Old 02-01-2022, 01:31 PM
The BallSS's Avatar
Before anyone says it, I know I'm necroposting but I was curious if you are still running this kit and if the flex coupler gave you any issue?
Quick Reply: 98 Camaro 408 S488 Huron speed v3 t6 hotside kit.
