Trunk mounted meth set ups. Need some ideas
Old Apr 20, 2017 | 12:01 PM
jimmyg's Avatar
Default Trunk mounted meth set ups. Need some ideas
Need to mount a small meth tank and pump in the truck of my 83 cutty. Any body have a similar set up? I just don't want to drill a bunch of holes in the trunk. Need to fig out some kind of bracket set up. Ideas?
Old Apr 20, 2017 | 12:16 PM
svslow's Avatar
Do you have a picture of your trunk?
Old Apr 20, 2017 | 12:38 PM
jimmyg's Avatar
I can post one prob tonight.
Old Apr 20, 2017 | 12:42 PM
svslow's Avatar
Something like this an option?
http://i107.photobucket.com/albums/m...00510-1356.jpg
Old Apr 20, 2017 | 03:48 PM
3 window's Avatar
I put a bend in a piece of 16 ga steel and mounted my tank and pump to it. All wiring is behind through a weatherpack connector. It's a 3 quart tank. Two holes is all into the trunk floor.
Old Apr 20, 2017 | 05:16 PM
jimmyg's Avatar
Yes that looks perfect. That is the same set up I'm using .Is that free standing? Just mounted to the trunk? Did you buy the solinoid?
Old Apr 20, 2017 | 05:23 PM
jimmyg's Avatar
Originally Posted by svslow
No . Old school trunks don't have all the panels like the newer stuff.
Looks like this, but a battery box mounted in center of shelf.
Old Apr 20, 2017 | 07:33 PM
truckdoug's Avatar
fab a little bracket and use the 2.5 gallon agrimart tank and put it in the spare tire well
Old Apr 20, 2017 | 08:14 PM
3 window's Avatar
Yah, it's free standing. The 16 ga is pretty thick. I'm not using the solenoid, but I also haven't run the kit yet either. My car's currently on E85. I'll be running it once I switch to a lesser ethanol content fuel.
Old Apr 21, 2017 | 06:54 PM
stevieturbo's Avatar
Alcohol Injection Systems makes some nice tanks ( now called ProMeth )
Old Apr 24, 2017 | 02:25 PM
lower_the_dynamite's Avatar
I found this 2 gallon tank and breathable cap at US Plastics website under $35.00. They have a lot to choose from and the design docs available for all specs. I'll post the link here but it might be removed by an admin. Good luck!
https://www.usplastic.com/catalog/it...4163&catid=578
Old Apr 24, 2017 | 05:24 PM
ls1curt's Avatar
fbody one i'm working on. The pump is mounted to the inner fender. And my notch.
