5.3 e85 eaton m122 12psi, custom intake on a budget
02 5.3, 2000 ls1 cam, dual valve springs, 80lb injectors, e85, custom sheet metal intake, intercooler, ford gt500 eating m122 supercharger, 102tb, a1000 pump, boost reference regulator. Made 12 psi on dyno, 375hp, blowing through the converter pretty bad. Hoping to get back to dyno in a week or so with different converter. All custom bracket, and mounts, added 2 more ribs to the stock ls1 balancer. 8 rib belt.
Start of intake
Intake is all 1/4, with 9/16 thick plate on top. Plate ended up being 1/2 after i milled itwarping it..
Idler from scrap aluminum.
Before extra grooves
After a little lathe action..
Intercooler
Balanced pinned
Pinning tool I made
Custom Manual tensioner
Intercooler rad mount
Finished project
Intercooler
Balanced pinned
Pinning tool I made
Finished project
The following users liked this post:
truckdoug (04-21-2020)
I don't have anymore pics of intake coming together... The intercooler is from ebay. The core is 4.5x5.5x12. The water in and outlets are on the back of the intake. Had a lot more room in my sandrail then most cars. Thanks guys!
Was really hoping for 450-500 at the tires. Will see what a new converter does. Not sure how much hp I'm losing blowing through the converter. It only weighs about 2200lbs. Thanks for compliments! I like to fab and be different...
James Estupinan (04-21-2020)
im curious how it run . and if there was any lag
