Turbo help
Old May 17, 2017 | 06:41 PM
Tom Curtis's Avatar
Default Turbo help
My set up right now is 5.3 SBE with a Huron V2 a/c kit. On3 tc78 turbo bov, waste gate. With a 4l60e and fti 3600 stall 3.23 gear. Cam is a 219/223 114+3. Car pulls good up to 6500 rpm running about 8-9 lbs of boost but is a turd from a dig. It won't even spin the tires through the rear brakes. Any suggestions?
Old May 17, 2017 | 09:02 PM
turbotrks's Avatar
Is this an EFI setup? 2 biggest factors I'd say are timing and AFRs. At WOT you don't need it any richer than about 13:1 until you get over a couple lbs of boost, then as the boost climbs you want it richer (around 11:1).
As for timing, if it's too low, it'll be sluggish until the boost comes in.
Old May 17, 2017 | 09:15 PM
Tom Curtis's Avatar
Timing is maxed out about 16. I believe I'm a little lean also
Old May 17, 2017 | 10:43 PM
truckdoug's Avatar
at what TPS % is your PE/BE table set to kick in?
Old May 18, 2017 | 11:32 AM
svslow's Avatar
What do you mean "maxed out" ?
Old May 19, 2017 | 01:35 PM
truckdoug's Avatar
whoa 16* on pump? take some timing out. like A LOT unless your on corn or race gas.
then try having your PE command more fuel starting at like 50% throttle.
I set mine up like that after RonSSnova told me to, builds boost WAAAAY faster.
Old May 19, 2017 | 02:37 PM
newschool72's Avatar
Is 16* bad at only 8-9 psi ? I have mine setup to make 13* at 12 psi ( Not an LS style EFI system ) . Mine is at about 17.5* at 9 psi. Am I way off ? Because of other situations , I havent made more than 6.7 psi. Have my other issues saved my SBE by not getting into higher boost ?
Old May 19, 2017 | 06:19 PM
truckdoug's Avatar
doh i missed where he said 8-9psi max.
hell i dunno really. I am super conservative now after hurting my motor.
new motor and tune I'm at 16* at 5psi (70/30 water meth starts at 5.5psi) and 13* by 9psi at like 10.8 on the gasoline afr scale.
when I turn it back up to 15+ psi i'll run about 10* and creep up on timing checking my plugs each increment
also we have 91 at the pump here, which varies wildly in quality.
Old May 19, 2017 | 06:22 PM
Tom Curtis's Avatar
Car goes back to the tuner June 5 so we will see.
Old May 19, 2017 | 06:25 PM
truckdoug's Avatar
get more details about your tune. there are some very talented dudes on here but you gotta give them lots of details or they won't even respond to your questions, they just assume their answer will be lost on you
Old May 19, 2017 | 06:28 PM
Tom Curtis's Avatar
I have hp tuners with the tunning school books but just learning it I didn't want to try with a turbo set up.
Old May 19, 2017 | 06:54 PM
Yea, we are lucky enough to have 93, but its laced with corn, like E10, so it will fluctuate some too. I can get race gas a few miles up the road were I get my 93 at Sunoco, but Id rather tune for 93 and be done with it. If I can haze the tires at 80 mph, why run race gas? so I can tune to haze um at 90 ?
Old May 19, 2017 | 07:25 PM
ddnspider's Avatar
Can you post a tune file? You need to log boost or at least have a friend watch and see what rpm it starts making decent boost. Below that rpm treat it like NA and lean it out and add timing and it'll wake the car up big time. The timing will make more of a difference than the AFR. When you're tuning on pump gas you always start fat with low timing like 10 degrees and then once you find your AFR then you start adding timing to it, but you still need a clue when it makes boost at all and when it makes full boost.
Old May 22, 2017 | 10:50 AM
RealQuick's Avatar
I am running 16 deg @ 16psi with stock ls3 short block... 93 and meth though.
Old May 22, 2017 | 11:25 AM
ddnspider's Avatar
That doesn't count if you've got meth. No way I would run that timing at that boost level.
Old May 22, 2017 | 11:38 AM
RealQuick's Avatar
i wouldn't run it without meth either.
