How To - Threaded IAT sensor in Intake
Old May 23, 2017 | 06:06 PM
AlexLSx7's Avatar
Default How To - Threaded IAT sensor in Intake
Hi guys.
It took me a while to find some decent info on placing the IAT in the intake including pics. So i thought i would take some pics of mine after I did it.
My car is a twin turbo LS3 which is nearing the end of its completion finally.
I put it in the intake as i am going to be running 50/50 meth to keep the cylinders cool as i'm currently on a stock block and wanted as much distance as possible for the meth to atomize as i have a very short distance between my intercooler and the throttle body.
I drilled a hole in the side of the intake about 16.5-17mm using a stepper drill bit, just so it was a bit smaller than the threaded part of the sensor.
I then carefully lined up the sensor and very slowly eased it in with a long socket so it threaded the plastic, no need for a tap.
Once it was in i slowly unwound it, wrapped the thread with some PTFE to help prevent any air leaks and slowly wound it back in.
This is what it looks like -
I was pretty happy with the way it turned out and looks almost OEM.
I hope it helps someone out
Old May 23, 2017 | 07:32 PM
rpturbo's Avatar
I like it.
Thanks for sharing
Old May 23, 2017 | 09:30 PM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
I would have certainly taken the time to use a proper tap, but if it works, good for you.
Old May 23, 2017 | 11:26 PM
AFTER HOURS MOTORSP's Avatar
Its only plastic. Done it a bunch of times this way.
Old May 24, 2017 | 01:34 AM
AlexLSx7's Avatar
The plastic is surprisingly soft so the metal thread tapped itself just fine.
Old May 24, 2017 | 11:16 AM
SethU's Avatar
Not surprising. I'm sure there's people out there that would tap a 2x4 for a lag bolt. But, if it works for them, good for them. LOL
Old May 24, 2017 | 03:22 PM
Cwarta's Avatar
Very nice! Did the same thing a few months ago. I did cut the cage off of my iat thermistor though.
Old May 24, 2017 | 03:28 PM
AlexLSx7's Avatar
Thanks. Any benefit to cutting the cage off?
Old May 24, 2017 | 04:22 PM
Cwarta's Avatar
I believe just more direct airflow/faster response time on the sensor
Old May 24, 2017 | 04:40 PM
Black_Sunshine_99's Avatar
I placed mine in the charge pipe, any advantage to putting it in the intake?
Old May 24, 2017 | 04:57 PM
pdxmotorhead's Avatar
I've always been told that keeping the temp and pressure sensor after the throttle body is the most consistent location, and tells the best story about the air at the valve, but thats all because "somebody said so" not because there was some research that said so.. Interesting simple question..
Old Jun 26, 2017 | 06:14 PM
AlexLSx7's Avatar
I put it there so i know thats the temp of the air going into the manifold. Plus its further away from the meth injection
Old Jun 27, 2017 | 10:00 PM
gametech's Avatar
As with anything, you add up the plus and minus. The charge pipe gives you a better reading of the intake air temps, but the manifold gives you a better reading of what temp hits the cylinders. Since the GM computer gives you a bias table that relates IAT to ECT, the best result could be very time consuming to quantify, and perhaps not the best use of your tuning time. The difference between plastic and aluminum intakes could bias any results significantly. I'm sorry that I don't have the capability to give a better answer, but this really is a complicated issue to generalize an answer for. The good news is that almost the only time this becomes a real issue is during episodes of slow traffic and high heat soak.
