Gear ratios and boost
im running almost exact combo as you, but on a 26"-27" tall tire n went with 3:25
I was told once that turbo lights off, you ll wanna be in it for long as possible. The yee haw effect.
Depends on the application and what you're going to do with it.
Gear it for the application then spec a converter accordingly.
Prior setup:
Car:96 Z28
Engine: Built 2002 5.3 (PRC stage 2.5 heads, ISKY triple 12 cam(212/212 .56x/.56x LSA 112), Wiseco forged pistons, Compstar H-Beam rods, balanced/blueprinted)
Turbo: PT7675 .96 A/R billet wheel
Hotside: CXRacing tubular header design (no crossover)
Transmission: Built th350 w/transbrake and Precision Industries Vigilante (4300 stall)
Differential: Ford 8.8 Hybrid (uses stock GM 7.5 10 bolt legs on an Explorer center section) and 3.08 gears
Tires: 315x35x17 M/T Drag radials
Issue: Blowing through the converter. Shifting from 1st to 2nd, RPM only dropped 200rpm and from 2nd to 3rd, 300 rpm.
New setup:
Regeared the differential with 3.55 gears.
Installed a new PTC spragless TC configured by Dusty for my setup/goals (Light daily driver with weekends at the drags). Fluid, per Dusty’s suggestion for the transbrake application, is tractor fluid.
Took several days to break in the gears properly, then took the car out today to test a few things.
1. Transbrake and Stall – I’d always read you could tell the stall of a given torque converter by activating the Transbrake and flooring the gas. That seemed to make sense to me, though I’d never tried it till today. I found a secluded spot (ie: no traffic), activated the transbrake and then floored the gas. I watched the tachometer as the RPM’s began to climb. To my surprise, It got up to 5K pretty quick and had built 9psi of boost. Woot! I think I’ve been mis-informed about the stall determination from transbrakes. Obviously, it’s not stalled to 5K. I’m pretty excited at the prospect of trying to launch the car when the strip is open again.
2. I found an unoccupied stretch of straight highway, stopped and then pressed the gas as aggressively as I could while maintaining traction in first, then wound it out to 5,788 rpm(52mph), then shifted. On the shift, The RPM dropped to 4,939. A LOT better than the 200rpm drop with the Vigi. Then wound it out to 6,111 in second(94mph) before shifting to 3rd. The rpm dropped to 4,939 rpm on that shift. So the PTC TC is working great.
Thanks for all your guidance and help Dusty and the rest of you good do-it-yourself guys on this board.
Dave
