Project Hairy Banana (1967 Camaro single turbo)
Old 04-12-2018, 09:28 AM
  #181
06_Chevy's Avatar
Let's see if these work:
Twin Scroll? Are you concerned about the distance of the drivers side crossover to the passenger?
Old 04-12-2018, 10:05 AM
  #182
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,148 Likes on 746 Posts
I'm not knowledgeable enough to answer that to be honest.
Anthony (Manna) liked to the room to keep everything from heat soaking. Added bonus was the room to run the down pipe out the fender.
Old 04-12-2018, 12:50 PM
  #183
R_trim 93GT's Avatar
Originally Posted by Hellsx
Aaah, there you go, "turbo stand" is the right term. I never got that right, sorry. But yes, i would really appreciate if you would.
Here was my solution on a single turbo kit for a 72 Nova that has gone 5s in the 1/8th.
Old 04-23-2018, 05:21 PM
  #184
LS1Tech Co-Founder
Was away for 1.5 weeks in Asia for travel, ready to get back on the build.
Car has been back at my house for over a week.
So concludes Phase 1.
Phase 2 is wiring, mostly at my house.
Phase 3 will be brakes/ fuel system at Manna's shop.
Old 04-27-2018, 05:37 PM
  #185
LS1Tech Co-Founder
Neighbor liked my new shiny radiator:
Old 04-27-2018, 06:20 PM
  #186
M_Minnick's Avatar
Twins!
Old 04-27-2018, 06:25 PM
  #187
LS1Tech Co-Founder
Nice. Based on your sig, similar builds. E85?
Old 04-27-2018, 06:30 PM
  #188
M_Minnick's Avatar
Pretty similar. Made 840rwhp on a Mustang dyno on 22psi and first trip to the track went 9.20 @ 153. Having a hard time getting it to spool, only went 1.55 60' on that pass. It is on E85.
Mike
Old 04-28-2018, 08:47 AM
  #189
LS1Tech Co-Founder
Interesting info, we'll have to compare notes on spooling when I get this going. Do you have a build thread?
This phase, I just need to pull out the wallet and buy more stuff.
Old 05-01-2018, 09:18 AM
  #190
LS1Tech Co-Founder
Okay forum loyalists,
I'm looking for a truck alternator, high output. Recommendations?
Old 05-01-2018, 09:31 AM
  #191
cam
cam's Avatar
Stock Escalade alt are high amp, 140 iirc, but huge ( yuge? ) and heavy although cheap and a plenty.
Car audio alternators can be had high output in small packages, but they are pricey. We bought a 200amp f-body sized ones years ago for a friends car that was audio crazy and iirc it was about $500.00
Old 05-01-2018, 10:01 AM
  #192
LS1Tech Co-Founder
That's what I want, cheap, plenty.
Old 05-01-2018, 10:07 AM
  #193
cam
cam's Avatar
Yup makes sense. Do the one wire resistor excite mod so it runs no matter what. Spinning? Charging. Easy mod search it out its listed in detail on here
Old 05-01-2018, 10:51 AM
  #194
47ford's Avatar
Go to the local yard find the cleanest alternator you can find (one with the 4 wire plug) buy the Holley pig tail with the resistor built in it and hook to 12v..... 50$ and good to go
Old 05-01-2018, 11:00 AM
  #195
LS1Tech Co-Founder
All the yards by me are pretty far...
As soon as Manna signs off on this one I will order it:
https://www.rockauto.com/en/moreinfo...c=2650&jsn=523
Old 05-01-2018, 11:57 AM
  #196
47ford's Avatar
That’s a two wire one.... you need one with a wide 4 wire plug, search under like a 2004 avalanche Tahoe etc.....with this pig tail
https://www.summitracing.com/parts/h...SABEgKclvD_BwE
Old 05-01-2018, 12:39 PM
  #197
LS1Tech Co-Founder
Are you sure on that?
Old 05-01-2018, 12:50 PM
  #198
Forcefed86's Avatar
Are you running truck spacing? Or were you just going to make the truck alt "work"?
Could try a 160A one wire self exciting alternators on Ebay. I've ordered 3 now. had good luck with all of them. They are the smaller Fbody style alternators, but I'm surte thay have the truck alts as well.
https://www.ebay.com/itm/LS1-CHEVY-F...item28583321a7
  #199
LS1Tech Co-Founder
truck spacing
Old 05-01-2018, 12:54 PM
  #200
LS1Tech Co-Founder
4 wire, this one?
https://www.rockauto.com/en/moreinfo...411827&jsn=414
Quick Reply: Project Hairy Banana (1967 Camaro single turbo)
