Project Hairy Banana (1967 Camaro single turbo)
#602
LS1Tech Co-Founder
Got it running last Saturday. Worked through 3-4 small issues, and then it fired up nice on the 5th crank:
'Tech does not like FB links so you have to edit it to make it work
facebook com/john.ryan.lsx/videos/10221174486220442/
The following users liked this post:
Reckless (12-02-2019)
#606
LS1Tech Co-Founder
I'll take the one on the left thanks.
Next? Kinda goes like this:
1. Swap on the replacement water pump. #1 weeped in front, was told by some knowledgeable guys that it was bad. So I bought a new one, and had Hambone Fab weld on the 16AN fitting and close up the hose inlet/outlet on the side.
2. My local buddies want me to change some of the wiring, so bought a new Holley main harness ($60) so that's powered right to the battery not how it was done when another buddy did the board. Also adding some bigger relays and changing some other parts of the board. I also need to run the lines to the waste gate and the line for the dome pressure sensor.
3. I have to address the rear end. Car has ladder bars and a Ford 9 inch out back. The center section looks like a stock Ford piece. I pulled an axle and counted 31 splines but none of us have any confidence that the guts will hold up. So I'm saving up for a new / used center section, axles and driveshaft. NOW in the meantime if I find a smoking deal on a drive shaft I'll swap one in cuz g'dammit I want to drive it. I have a DS here that I got from a buddy and it's 2 inches too short.
I could add more steps but I'll hold off for now lol.
![](https://scontent-ort2-1.xx.fbcdn.net/v/t1.0-9/78565987_10221262722266288_1355384231420755968_n.jpg?_nc_cat=106&_nc_ohc=Y7yuhR_xjxIAQmhvWmR3uBmDVctF2Ak6AFkOnvEE60wbsbk-puzJfdSIw&_nc_ht=scontent-ort2-1.xx&oh=393c767515ef35dfd6f43e3d32194dfb&oe=5E3E8B25)
#608
LS1Tech Co-Founder
One option is I upgrade the guts, have Hambone Fab weld a back brace and some gussets.
Another option is I get a new fabricated housing. I'm thinking I do that at some other point because I can get this one welded on for small money.
#609
Ugh, got similar feedback from other folks too.
#610
LS1Tech Sponsor
I agree on the center section being the weak link. I prefer a spool over a locker. I've driven cars with lockers that really wiggled the back end when letting off the gas. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
![](https://ls1tech.com/forums/signaturepics/sigpic168855_1.gif)
#611
LS1Tech Co-Founder
I had a locker a long time ago, it was kinda spooky not a fan. My 5th gen has a True Trac locker and drives like a posi to me. But I'll do a a spool in the banana.
#612
9" center sections are easy to swap out so id set up two; one for street with a posi, and one for racing with spool. 31 spline is fine until you start leaving off the brake under big power imo. Once you get to that stage your bet is to skip all the BS and go straight for a 35 spline set up. Buy another good third member and build it with the spool, 35 spline axles, all the ARP stuff etc. Full build. Then keep your 31 spine third member/axles and parts for street running. The old War cases are pretty dog gone good you'll want to check into what you have. Even if its not a war case they aren't "bad" just some are better than others. Trac loc for 9" aint bad at all and id be surprised if you munched one on the street but for the track or hard launches spool is mandatory. The last thing anyone wants is one wheel to bite and one to kick loose and have the thing turn hard on ya. Dangerous and happens a bit too often
As for your housing? It should be fine if your good with ladder bars double check all the welds and run it if it is built well. Maybe post some pics so we can help ya assess
Heres a launch with one wheel biting and one not
#613
#615
John, what gear are you planning to run? I have a brand new Moser aluminum through bolt center section with 4.11 and a 35 spline spool that I might be selling. I’ll know more after PRI.
#619
