Project Hairy Banana (1967 Camaro single turbo)
#1421
LS1Tech Co-Founder
Eddie also said we'd discuss cutting it or him using a press. I think he has to look at his options. My buddies lean towards me clearancing it to just get it out and redo the piping over in 5" in the winter.
The following users liked this post:
gjohnsonws6 (06-15-2023)
#1422
LS1Tech Co-Founder
Issue: Car shakes 70mph and higher. Really sketchy at 100mph.
I'm working through a list of items, so today I got the rears re balanced:
-Wheels are fine and not bent
-One tire took 12 oz of weight... dang
-One tire took 5.5 oz and has a slight flat spot
-Tires were fully beaded
So I'll throw them on and drive the car this weekend if the weather is good, if it's better then I don't have to pull the driveshaft.
I still need to have my buddy Eddie V clearance the exhaust. maybe he'll heat it up and use a press or want to cut and weld a section, I don't know yet. This is the plan for now. Some day I'd like to converter it to 5" but right now I want to make some passes in it.
#1423
#1424
LS1Tech Co-Founder
Reading my mind, totally thinking 1/8th.
I should share a pic of the wheel weights, I don't think they will stay on even with some tape. Leaning forwards getting a new pair of tires, I got these used with 5 passes from a buddy so I only have $80 into them.
Pro Stock John (06-27-2023)
The BallSS (06-20-2023)
The following 2 users liked this post by Pro Stock John:
3 window (06-19-2023), The BallSS (06-20-2023)
#1433
Excited for John to get out there and make some serious rips and not get rattled to death.
John, do you know if the tire shop tried rotating the tire on the rim to try and reduce the amount of weight needed?
#1434
LS1Tech Co-Founder
I honestly forgot to ask the tire guy about that when I was there, so I emailed him later. He said he thinks it would not have made that much of a difference, an answer that some friends agree with, others don't.
#1436
LS1Tech Co-Founder
Yeah some friends think it would have made a big difference but honestly with the other tire having a flat spot these tires are coming off.
@gjohnsonws6 great to have dinner with you yesterday, fun to talk about cars. I will say though today is crazy hot here and the air hurts my face.
#1437
Was a great time and I can’t get over that place. Thank you again!
It’s not even hot here yet lol. I’ve been outside in direct sun all day for three days straight now so I’m exhausted. It takes at least a couple weeks to get acclimated. I’ll be spending more time in the northern part of the state until fall.
Hopefully you get the shaking issue resolved soon and can comfortably make some test hits. 12 ounces is a lot, if new tires don’t do the trick it’ll be time to go after that driveline. I wouldn’t surprised if it needed a balance regardless of what the tires are doing. Is that the original one that came in the car when you first got it? Might
want to investigate what diameter, material, type of joints, and slip yoke it is set up with just to be safe.
#1438
LS1Tech Co-Founder
Yeah tires, and then see how it is. If it still has issue, which I think it won't, I'll pull the DS and have it re balanced.
Yeah that restaurant was great.
You are acclimated to this AZ weather. It's actually killing me lol.
#1440
LS1Tech Co-Founder
I was there 2 Xmases ago, was 60F and very nice.
I ordered MT DRs from Winners Circle, one of the last great speed shops in the greater Chicago area. Might be in today or tomorrow, will grab them and swap the rears.
The BallSS (06-27-2023)
