Borg Warner twin turbo sizing
-Iron block 5.7
-Brian Tooley stage 2 or 3 turbo cam kit (I could use some help picking which to go with too)
-Stock 317 heads
The car is a '93 Rx7 with a T-56 trans. I'm looking at the Borg Warner S300SX-E (I'm going with twins for packaging) but I'm open to other suggestions. Here's where I need some help. I'm not sure what compressor or turbine I should go with. I'm shooting for 600-700hp to the wheels with quick spool up. The S300s compressors range from 61mm to 69mm and the turbines are T4 inlets with either twin scroll .91 or 1.00 A/R or a .88 open inlet. I have heard that you can get a T3 hot side for the S300s too.
The car is going to be driven on the street primarily so I'm more concerned with area under the curve than peak hp. Hopefully I didn't leave anything out, and thanks in advance for the help!
-John
* 870whp was 23psi**
Here is an in car when I was testing my home made 2 stage boost controller. Gives you and idea of how boost recovery was
