Huron twin turbo kit with high ram or super Vic?
Just bought a huron v3 twin kit for my 408. I was wondering if anyone has used one of these intakes and what you had to do to make the kit work for these intakes? Thanks
I'm afraid you're going to run into the issue of since those intakes sit higher you will have to extend the cold pipe that runs to the TB. Which means you will likely run into hood clearance issues. On a dedicated race car cut that **** out. On a street car it could cause some big issues. Might be able to get a massive cowl hood to make it fit.
I figured that I would have to extend the pipe which isn't a big deal. I just wasn't sure if the high/mid ran or vic with an elbow pushes further towards the front of the car. I'm not worried about clearance. I have a ws9 outlaw hood and I don't drive it on the street too much at all
There's a 7 second car in this forum running stock LS3. By the time we've shored up everything else to run good number and circled back to manifold it usually isn't worth it. I run a ported LS3 and make 1k plus and can run mid 8s so if you're planning on more than that then spend the money I guess. For the Huron guys there's usually better places to drop that kind of coin is all.
Building a Boosted 370 myself with the High Ram. Don't use mid Ram, will lose power. I've done a TON of research on Inatkes. I went from GEN1 SBC world, to the LS world. So I must verse myself in this stuff now. But read this, it explains it all. If you wanna go stock style, go LSX-R. If you have the room Holley HR.
http://www.hotrod.com/articles/20-ls...ifolds-tested/
LS1Tech Sponsor
Cold side tube is made to run to the stock TB location. If moving the TB location via different intake manifold you will simply have to modify the upper charge pipe to run to this new location. You may be able to make it happen with some form of coupler, put the proper way to do it would be cut and weld..... or run an intake that ends in the OEM location
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Truth is an OEM intake is plenty in a forced induction application... they just lack the look cool factor of an aftermarket intake.
